New hood emblem
Old Jul 10, 2017 | 03:49 PM
smrtasp's Avatar
2017 AMG GT
Originally Posted by tresean1
is that the same emblem that garthbo is referring to? I know there are two part #'s: one that ends in 1801 and one that ends in 1701
I believe so. That's the part # that is in the picture at the start of this thread (minus the leading A) at $25.90 before any tax and shipping.
Old Jul 10, 2017 | 10:48 PM
garthbo's Avatar
2016 MB AMG GTS
Yes, mine ends with 1801 (no pinch springs at the back). I have ordered now the trim removal tool from amazon. Hopefully, I can remove my old emblem without further ruining my paint.
Old Jul 10, 2017 | 11:54 PM
triblk6spd's Avatar
18 AMG GTR . 18 Tacoma . 02 BMW M3 (the sickness)
Quick note...we use this method on the regular. (package straps) laying down painters tape right near the edge helps with micro marring.
Old Jul 26, 2017 | 01:05 PM
raihak's Avatar
2017 C300 coupe Designo Diamond White Metallic
Originally Posted by xcfisher
No pinch spring on the c190; because it actually mounts to the bumper like an emblem ..Just 2 small pins with built in grommets. My buddies c63 has the pinch spring, hence my extended search for the correct part! install is 60 seconds. Pop the old one out with an interior panel tool, snap new one in!
Can you share the part-number for your friend's C63? I have a C300 and I'm looking for the genuine black emblem. On ebay its $60-80. I'd like to find it on Genuine MB parts.
Thanks.
never mind... I found it:
000-817-17-01
Old Feb 25, 2018 | 06:44 PM
MariTheBoss's Avatar
2015 C300 4MATIC / 2017 C43 AMG
Quick Install ‘17 GLC
I, like some members above, had some difficulty with installation due to how flush the emblem was with the hood. I could not get a trim tool, a credit card, or even floss to get under the emblem in order to lift it out. As a last resort, I ended up using a 90 degree pick to stick in the side of the old emblem- once inserted, it lifted right out. Happy embleming!
Old Mar 16, 2020 | 12:12 PM
AMG 17GT's Avatar
R Nine T
Correct. Use an interior panel tool:
You can purchase a set on amazon for like $6 bucks. Here is a link.
Do NOT use a metal tool. These are a hard plastic that wont mess up the paint. Just put it under the edge, pry it up a mm or two, and then go 180 degrees, repeat, go 90 degrees repeat, 90 degrees repeat and it will pop straight up without damaging it - or the vehicle.
i would also place painters tape on top bottom and sides where you pry.
Old Jul 6, 2020 | 08:56 PM
  #32
realien's Avatar
2016 AMG GTS
Thanks for this tip, just did mine with a nylon pry tool (I have a set since I'm often disassembling doors and dashboards on friends cars )
Old Jul 12, 2020 | 07:11 PM
  #33
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
The crossbar... is not structural. The plastic surrounds pop forward with little effort, and the bar itself is held in place with 2 small T30 Torx head bolts. Takes 2 minutes to remove. It actually looks nice simply removed all together! A solid cap to cover the two holes would be simple to make.
The crossbar absolutely is structural! You have a carbon bar connecting the sides of the chassis/rear shock towers, where you have the max lateral flex. There are 2 hefty Torx bolts on each end.
Who did the work? The plastic caps on each end of the strut bar are INCREDIBLY HARD to put back. At least on mine, it was a NIGHTMARE. Ended up using double sided tape as it was impossible to clip back in. And access is a real Pain - the front seats don’t move far enough forward to give you access. If you did this yourself, how did you do it?
Old Jul 12, 2020 | 07:16 PM
  #34
x96535's Avatar
2016 AMG GTS
Mine snapped back into place real easily (I have a carbon fiber strut bar). Strange you and others had such a hard time.
Old Jul 12, 2020 | 07:27 PM
  #35
Surge's Avatar
I have the carbon bar too. Interesting. I could not get the plastic cover to snap back in. And the plastic cap scratches the gloss carbon finish very easily, as it slides back and forth. I was able to remove the scratches with Poly Watch.
How did you access it? Did you remove the seats or lie in the back cargo area?
