Let's Talk About Maintenance...
There have been multiple service intervals given here for the 190 series car, but these are from the factory documentation which was current for my 2016 GT-S.
It is not much different than the earlier version, but for us, the main change is in the transaxle service schedule, which was changed from every 40,000 miles to every 30,000 miles.
If one does not drive a lot, you can convert every 10,000 miles or 16,000 km to one year. So, in the example of the transaxle service, it should be done every 30,000 miles or $3 years, whichever occurs first.
See post# 269 above for current schedule and a downloadable PDF
Here’s the logic:
Almost all MB/AMG models are built on very similar platforms, so their service intervals are largely the same, with only a few exceptions.
The core idea is that the dealer sees the car every 10K miles or 1 year, hooks it up to the Xentry diagnostic system, and performs both electronic and visual multi-point inspections.
If anything is out of spec that isn’t part of the standard service interval, they’ll flag it for you. Otherwise, there’s nothing to do beyond the regular interval maintenance outlined in the service brochure.
One additional recommendation I’ve heard consistently from multiple service techs is this: if you track the car, add an extra oil and filter change between the 10K-mile service intervals — essentially, change it every 5K miles. Brake fluid can also be accelerated based on your track usage. (You can also ask for a multi-point inspection at the 5K mark, just to be safe, if that gives you more peace of mind
)The GT platform is solid, don't overthink the maintenance.
(Please forgive me for asking all these questions, but since I may purchase a GTC/GTR in the future, I need to know all the pros and cons of this stunning car!)
Open the PDF attached to post # 269 above, or check with your local dealer.
Even on Ferrari (USA), which originally designated this Getrag 7DCL750 Transaxle as " filled for life" , changed it to 30K Miles.
experts opinion needed...
I'm in the process of negotiating the purchase of a GTR registered in February 2022 with 3,400 miles on the odometer. Assuming for a moment that the maintenance schedule is the same for both the North American and ROW markets, could someone tell me specifically what maintenance should have been performed on it so far? The dealer showed me the maintenance history to date, and I see a Service A in 2023, a Service B in 2024, a Service A in 2025, and a Service B this year, but what was done during each service isn’t specified... thanks
P.S. I still don't understand why a thread as important as this one has to be searched for among all the others every time, instead of being pinned... Could the moderator of this section kindly take it upon themselves to move it?
You may want to do the diff and trans fluid at 4 years; but I’m just doing mine now.
Good luck and enjoy!
AS a matter of fact I would rather replace fuel injectors or spark plugs (which I have done) than replace that dam filter. Would be easier if passenger seat was removed but I did not do that.
Ps throw in brake fluid changes, trans fluid changes, and exhaust actuator valve replacement. All easier than replacing that filter.
I'll do mine at 20,000 km - I don't see much point in doing it sooner as it doesn't degrade over time.
@Kevin#34 just my 2-cents: you are better off getting the car professionally inspected by an AMG mechanic whom you trust, then relying on this “if there’s even a signal bolt that MB specifies… I expect it to be replaced!”. I get where you are coming from, but this will be nearly impossible to prove if something goes wrong. The fact is that it’s pre-owned and out of warranty, so anything can happen.
I don’t want to discourage you - they are great cars and very reliable.
PS: the " a single bolt to be replaced" was obviusly just a way of saying...
I am not familiar how MB in IT works but I know MB DE and MB FR has a RO similar to what most US based dealerships provide. You need to ping SAGA and CENTRUM individually to ask them to provide the actual RO. I do think there has to be a digit after service A or B. With that digit, you can decipher which services are supposed to be completed.
