Is this the oil filter housing & cap?
Subscribe
May 8, 2017 | 06:22 PM
So is that the oil filter housing and black cap with the yellow stripe shown in the #3 under-car photo posted by Dr. Graphx (thank you) at
https://mbworld.org/forums/amg-gt-gt...-car-view.html
and will all the oil in the dry sump tank come rushing out it one removes the housing to replace the filter?
Reply 0
May 8, 2017 | 06:45 PM
Hey slk55er, check out my post,
https://mbworld.org/forums/amg-gt-gt...intenance.html
I discuss all things maintenance, including procedures! Hope this helps
Reply 2
May 8, 2017 | 06:47 PM
Quote: So is that the oil filter housing and black cap with the yellow stripe shown in the #3 under-car photo posted by Dr. Graphx (thank you) at
Yes the yellow stripe cap is the filter. So, no not all of the oil will rush out, but a good bit will. You will need to drain the reservoir first, then the drain plug, and filter housing. About 7.3qts total
Reply 1
May 8, 2017 | 07:08 PM
Thank you much!
Reply 0
Subscribe
Currently Active Users (1)
