AMG GTR brakes failure - Mercedes refuses warranty
Besides changing the brake fluid to Castrol SFR, what other recommendations?
Recommendation for pads? Are the stock pads good enough if > 50% for track use?
I will probably need stability control in early stages, but i read elsewhere to use Race mode and turn ESC off to prevent excessive rear brake wear.
My track experience: tracked a sport bike (R1) 10 years ago for several years, only been on the track once with a car (SLK350).
Is extra brake cooling recommended? If so, what are the current options? (the renntech brake cooling option is more than I'm willing to spend right now).
what pads do you run? Model number?
"monitor your tire temperatures" how? Brand of IR temp reader? What am i looking for? What do i do with the info?
brand of cooling ducts recommended? How long to install?
Thank you!
Thank you!
Iron rotor option pictured,but you can buy carbon shape as well.
I use factory pads so far...
you can use an IR temp, and some cars actually display tire temp on the dash... also pressures depend on the tires but usually around 32-36 tire dependant...
so far TIKT is the way to go but I haven’t done anything other than cool down laps and never engage the parking brake in the pits
Thank you!
I see your dust boots is too bad, but if you can with me check the front and rear caliper piston size, I can sell you the dust boots (front is heat-resistant dust boots, and they can bear to 300 °C),
my gmail is this :BCBBRAKE@gmail.com
