AMG GTR brakes failure - Mercedes refuses warranty
Old Jan 11, 2019 | 07:55 PM
  #101
spyder987's Avatar
Exclamation
1
Last edited by spyder987; Jan 14, 2019 at 12:08 AM. Reason: Avoid any further ridicule
Old Jan 11, 2019 | 09:13 PM
  #102
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
Originally Posted by spyder987
I took my SL65 with CCBs (2500 miles) to Laguna. Ran 2 sessions 11 laps each. I am a 7/10 ths driver. 1:48-1:50 per lap. RACE setting, ESC on. 2/3 of the way thru the first session the pedal went to floor. It pumped back up. Second session, same thing. Pulled into the pits after the 2nd session, front rotors had a 2mm grove near the outer edge with a trail of brake/rotor dust. Took it to the dealer. $16,000 repair estimate. Rotors, calipers, pads, hoses, sensors, bolts, wheel bearings, etc. Dealer said no warranty. Currently working with US MB customer service.
Notes on the diagnostics: Overheated the brakes, caliper dust boots cracked. Sensor wire harness melted. Rotors are grooved all the way around. Pads are at 8 mm front and 10 mm rear.
So in my case pad wear was not the issue. As others have said in this thread, AMG markets these cars as being track capable with a RACE setting.
The pictures of my rotors look the OP's.
Good news, the SL didn't blow sound!
So you think the SL65 is a track car ?
Without track prep ?
Old Jan 11, 2019 | 09:20 PM
  #103
spyder987's Avatar
Old Jan 11, 2019 | 11:12 PM
  #104
ronin amg's Avatar
[QUOTE Never said it was a track car. Why would you insinuate that? ............I took my SL65 with CCBs (2500 miles) to Laguna. Ran 2 sessions 11 laps each. I am a 7/10 ths driver. 1:48-1:50 per lap. RACE setting, ESC on. 2/3 of the way thru the first session the pedal went to floor. It pumped back up. Second session, same thing. Pulled into the pits after the 2nd session, front rotors had a 2mm grove near the outer edge with a trail of brake/rotor dust. /QUOTE]
Duhh
Old Jan 11, 2019 | 11:29 PM
  #105
spyder987's Avatar
Old Jan 12, 2019 | 09:21 AM
  #106
AMG 17GT's Avatar
R Nine T
Spyder, I believe he’s being captain obvious in that you tracked 22 laps with warnings of brakes overheating.....
Old Jan 12, 2019 | 10:30 AM
  #107
spyder987's Avatar
Old Jan 12, 2019 | 11:10 AM
  #108
thebishman's Avatar
‘24 BMW iX M60
Not at all. It was a high performance driving event (HPDE). I wasn't out to set a lap time. I simply provided that as a point of reference for those who know Laguna.
I checked with my dealer before hand. They didn't advise anything special regarding setup and in fact said that some of their customers do track their cars.
I asked about brake fluid and they said it is intended to match the performance of the brake system (assuming that is what you referenced as a 'warning' which I interpreted as brake fade).
It is obvious to me now that crass individuals like ronin should not bother responding to posts like mine. His choice of language is offensive and reflects on his lack of any integrity.
Phil,
I’m sorry what happened to your brakes and the costs you’ll incur, but for anyone who has driven various cars on track, this was an event just waiting to happen. You received very poor advice from your dealership btw!
A heavy car like the SL65 relying on its ESC to remain stable on track is going to extract a very heavy toll on its brakes; it simply is not a reasonable choice to be trying for quick laps on any road course unless you’ve prepared the car. By this I mean: change the brake fluid to an ultra high quality DOT 4; (you lost the pedal on track by ‘boiling’ your brake fluid); attempting to find some more road course oriented brake pads instead of the street pads that the SL65 comes with, and I hate to say it, drive the car at 5/10, not 7-8/10. If you want to be that committed find a car that can take road course ‘abuse’ in stride at an HPDE for 20-25 minutes; (and in my experience the GT R can easily do so), or buy a dedicated track car after you’ve gotten tons of experience.
A ‘slow’ street car that can’t generate the high speeds of the SL and a car that weighs perhaps 3,000 lbs versus north of 4,000 lbs can maybe tolerate the abuse without any major issues, but those cars these days are few and far between because the vast majority of cars can generate decent speed and most also weigh far more than cars did 10-20 years ago. The BMW 3 series cars are a great example.
I hope that MB offers you some assistance with this.
Bish
Old Jan 12, 2019 | 11:33 AM
  #109
ronin amg's Avatar
Oh my, pointing out the fact that you were so damn stupid to take a heavy [4,000+lbs.] totally a street car to the track and beat on it is offensive.
So sensitive....
Old Jan 12, 2019 | 01:54 PM
  #110
chris135b's Avatar
MY19AMG GT-C; MY14C63-507 - former Audi B6 S4
Interesting post here.
Question: what rotor/pads/brake fluid combination does the Formula 1 Safety car have for the races? I have personally seen the safety car do 7 laps at Circuit Gilles Villeneuve during the Canadian Grand Prix (Montreal) and it did not have any problems with the extremely heavy braking zones.
-C
Old Jan 12, 2019 | 04:56 PM
  #111
thebishman's Avatar
‘24 BMW iX M60
-C
So the GT R is supposed to come with OEM DOT 4 brake fluid. I’m not sure if all MB’s with CCMs come with DOT 4; I doubt it as I bet it’s car specific, not brake system specific. Regardless I’m sure the F1 GT R has ultra high performance brake fluid installed. Also, the GT R’s OEM brake pads work very well in my experience as a great compromise street/track pad; however I wouldn’t be surprised if the F1 Safety car doesn’t come with the Pagid RSC1s which are more track oriented.
Old Jan 12, 2019 | 05:55 PM
  #112
ronin amg's Avatar
All of the AMG cars are using Mercedes branded dot 4. Mercedes doesn't even know the wet /dry boiling points of their branded dot 4.
I could feel the peddle get soft on my test drive through the canyons.
I had my dealership bleed and replace my AMG cars with Castrol SFR fluid before I drove them off the lot.
Old Jan 13, 2019 | 12:20 PM
  #113
boltonblue's Avatar
15 AMG S63 4-matic coupe
ronin, since brake fluids are anhydrous, how long do you leave it in the car before flushing with new?
Old Jan 13, 2019 | 12:28 PM
  #114
ronin amg's Avatar
I do mine every 6 months, so I've done it twice now and will do it again in May.
If the peddle gets soft I will do it sooner.
Old Jan 13, 2019 | 12:33 PM
  #115
boltonblue's Avatar
thx
Old Jan 13, 2019 | 03:28 PM
  #116
thebishman's Avatar
‘24 BMW iX M60
Castrol state that SRF needs to be exchanged, (flushed) every 18 months. Unless you’re tracking the car, in which case a quick bleed prior to each road course weekend is never a bad idea, you can leave it in for the 18 months and replace when you hit that amount of time. If the brake fluid replacement has been very well done, meaning no air bubbles in the system especially within the caliper, you should never experience a ‘soft’ pedal from SRF with a street driven car.
Bish
Old Jan 13, 2019 | 05:27 PM
  #117
BenzGTR's Avatar
2018 GTR and 2018 E63 Wagon
For the record I tracked my GTR with CCB's (stock rotors and pads with fresh SRF) heavily this weekend and I experienced zero brake fade. I'm a very fast driver pushing the car 10/10ths, had the second fastest lap time of the weekend on street tires.
When I get my Forgeline's and switch to slicks that will be the real test.
Old Jan 13, 2019 | 05:42 PM
  #118
chris135b's Avatar
Interesting.
I can say that when I looked at the Safety Car this year in Montreal on the Pitlane walkabout day (Thursday of the weekend) and during the AMG Tour in Affalterbach, nothing seemed "special" with the brakes other than them being CCBs. Next time I go back for the tour, I'll have to inquire more about the setup. 🙂
BTW, I HIGHLY recommend the AMG Tour! It is very enlightening to hear directly from the folks that build our engines!
-C
Old Jan 13, 2019 | 06:50 PM
  #119
ronin amg's Avatar
Bish
I have not experienced any soft pedal in my GTS in the canyons on it's steel brakes but I have had soft pedal even with Castrol SFR in my wagon with it's CCBs.
The oddest thing is the wagon developed soft peddle on the uphill with very light braking. The ABS/Traction control is very aggressive on the brakes.
I have never had a car going uphill develop a soft pedal before.
We need brake cooling airflow..
Old Jan 13, 2019 | 10:17 PM
  #120
MalibuScott's Avatar
2025 Lucid Air Grand Touring, 2022 F-150, 1926 Rolls-Royce SSG roadster
Would DOT 5.1 brake fluid solve all the boiling issues?
Old Jan 13, 2019 | 11:30 PM
  #121
BenzGTR's Avatar
That sounds like cooked fluid, or an air bubble
Old Jan 13, 2019 | 11:31 PM
  #122
BenzGTR's Avatar
Castrol SRF.
Old Jan 14, 2019 | 10:47 AM
  #123
thebishman's Avatar
‘24 BMW iX M60
No. DOT 5.1 is silicone based iirc and is not recommended in our cars as it can damage the braking system.
Bish
Old Jan 14, 2019 | 10:50 AM
  #124
thebishman's Avatar
‘24 BMW iX M60
Difficult to ‘cook’ SRF, even in an E63S wagon. The more times brake fluid is flushed, the more chances of getting air in the system. This is why I only exchange the SRF in my car once a year at a specialized shop, and then just do small bleeds as necessary. Getting small bubblies out of the calipers can be a huge PITA.
Old Jan 14, 2019 | 11:59 AM
  #125
ronin amg's Avatar
I only use SRF fluid since day one in my wagon and the fluid is pressure bled so their is no chance for air to enter the system.
The ABS traction control is just super aggressive on the CCBs. It works amazingly well with the 720 hp AWD of the wagon but it does cook the brakes and fluid going uphill in a 4,700 lb. wagon..
I guess I should stop videotaping Ducatis behind me in the canyons..
