Any news on GTR PRO ?
Did your dealer know how many US and Euro Pro’s will be made? I think the worldwide total was 150 wasn’t it?
Also, for the GTR Pro $35k base price bump over the GTR what do you get in enhancements/value?
A partial list is;
Manually adjustable coil overs.
Additional enhanced suspension bearings.
Stripes
Ceramic Brakes $10k
Carbon Fibre Packages I and II $9k
Additional Carbon Fibre front wing pieces.
Regards.
A partial list is;
Stripes
Ceramic Brakes $10k
Regards.
additional carbon aero bits
adjustable carbon torsion bars
additional carbon strengthening under the rear axle
lightweight wheels in grey
I'm assuming that 20kg weight savings includes the bucket seats?
New carbon roof (Already on the GTR)
additional carbon aero bits (Already on the GTR)
I'm assuming that 20kg weight savings includes the bucket seats? (Not Available in the US)
The new GTR PRO carbon roof is unique to that model. It has the dip in the middle whereas the regular GTR roof does not.
The GTR PRO exterior carbon packages are also different than the GTR... much larger front splitter, front flicks, front and rear side upright aero, etc.
Let’s be clear I am not arguing with anyone. I am attempting to spit ball the added value items to justify the $35k base price bump.
As I posted earlier, $19k of the $35k is made up of the ceramic brakes ($10k) and 2 carbon fiber packages ($9k) that are standard on the Pro.
The remaining $16k is made up of the items you mentioned.
#32
I'm assuming the stated $35k is in Canadian Dollars as my Canadian dealer quoted me the same figure.
So, if we add up all the included packages in CAD, they come to $30,850 or roughly $4,000 more for the PRO.
#33
Where are you guys ordering from and from which sales? I'm also in Canada 😊
#35
I wanted to delete the stripes as I think they do not look good at all. The color selection (if you can call it a selection) is crap, second I think the stripes on the side are a styling failure and are distracting but the dealer wants me to order them any they will remove them if I still don't like them when I see the car in person. They probably want them for a few marketing shots.
#36
Former Vendor of MBWorld
Limited-Edition GT R PRO
Limited to150 units in the US
Manually adjustable coil over suspension
Standard Carbon Ceramic Brakes, Exclusively painted black with white lettering
Functional “gills” on front fenders
Larger front splitter with aluminum supports providing greater front axle downforce
Adjustable Carbon Fiber Sway Bar on front axle
Exclusive Carbon Fiber Roof
Standard Matte Carbon Fiber Interior Trim and Crossbar, Carbon Fiber Package I, and Carbon Fiber package II
#37
GT R PRO Details
The new limited-edition AMG GT R PRO is characterized by further improved driving dynamics, in particular on the racetrack. Experience gained from the AMG GT3 and AMG GT4 racing cars was influential in its development, and no other current production Mercedes-AMG is as close to motor racing as the new AMG GT R PRO.
The new AMG coil-over suspension offers even more choice for tailoring the set-up to the particular track. As in professional motorsport, the driver is not only able to set the spring preload length mechanically, but can now also adjust the compression and rebound of the dampers. This is done quickly and precisely without tools via a click system with an integrated adjustment dial on the damper.
The AMG GT R is already fitted with Uniballspherical bearings at the lower wishbones of the rear axle. The AMG GT R PRO now gets these bearings also for the upper wishbones. They are significantly more wear-resistant than conventional wishbone bearings and due to their design have no play, which means toe-in and camber do not change even under high loads. As a result, the AMG GT R PRO can be driven with even more precision.
In addition to a host of carbon-fiber components, weight is saved by making the ceramic composite high-performance braking system standard. And exclusively for the AMG GT R PRO, the brake calipers will be painted black with white lettering.
Aerodynamic fine-tuning increases the overall performance of the AMG GT R PRO as well. The redesigned front apron was fitted with two flics at the sides made of clear-coated carbon fiber. The lower flics transition virtually seamlessly into the front splitter, which was extended further forward and is held by small metal braces that stabilize the front splitter at higher speeds. The air slots, or gills, in the front fenders effectively vent the wheel arches and contribute to reducing front-axle lift. At the rear, a clear-coated carbon-fiber aero element at the wheel arch on either side rises up vertically almost to the level of the tail lights.
The combination of all these measures significantly reduces front-axle lift without negatively impacting the aerodynamic conditions at the rear axle.
The AMG GT R PRO doesn’t only drive like a racing car, it also looks the part. The standard Carbon Fiber Packages I and II with front splitter, fins in the fenders, trim strips in the side sills, side mirrors, rear spoiler, and a diffuser with high-quality clear-coated carbon-fiber finish emphasize the racing inspired design and performance. Additionally, the carbon-fiber roof has been redesigned with a lowered center exclusively for the AMG GT R PRO.
Even before the world premiere, the new AMG GT R PRO has impressively demonstrated its performance potential on the racetrack: In early November, AMG brand ambassador and AMG GT3 racing driver MaroEngel completed a circuit of the NürburgringNorth Loop in exactly 7.04.632 minutes driving a still disguised AMG GT R PRO. This considerably bettered the previous time for the AMG GT R and demonstrated the great potential of the current AMG flagship model.
California John (02-21-2019)
#38
Standard Equipment for GTR PRO
Performance & Handling
Handcrafted AMG 4.0L V8 biturboengine
AMG SPEEDSHIFT® DCT 7-speed transmission
AMG High-Performance Ceramic Composite Braking System
AMG Performance seats
Next Generation AMG Performance steering wheel
AMG DYNAMIC SELECT
19”/ 20” AMG Performance Forged Wheels
Fixed rearspoiler with PROspecific aluminum brackets
9-Mode AMG TRACTION CONTROL
AMG CoiloverSuspensionwithmanual damping adjustment
Michelin PilotSport Cup 2 Tires
Carbon Fiber Front Fenders with Gills
Carbon Fiber Packages I & II
AIRPANEL Active AerodynamicSystem for enhanced cooling
Lower Carbon Fiber aerodynamic profile for enhanced traction
PRO Specific Front Apron with larger Front Splitter
Rear Differential, AMG electronic limited-slip
15.4” Front & 14.2” Rear brakes with Black-painted brake calipers
Active rear-axle steering
PROSpecific Carbon fiber roof with lowered center
Carbon fiber drive shaft and torque tube
AMG Performance Exhaust System
AMGDrive Unit Steering Wheel Buttons
Adjustable Carbon Fiber Sway Bar on Front Axle
Adjustable Steel Sway Bar on Rear Axle
Comfort& Convenience
Power/Heated/Memory AMG Performance seats
4-way power steering column
AMG stainless steel door sill covers
MercedesMeConnect-withtrial period
Rear load space cover and cargo net
Trickle charger prewiring (includes accessory trickle charger)
COMAND®Navigation
Dual-zone climatecontrol
AMG Track Pace
Active LED Headlamps with IntelligentHigh Beam Control
AMG Performance steering wheel -Full DINAMICA
Carbon Fiber Interior Trim –Matte Finish
Carbon Fiber Crossbar –Matte Finish
12.3” fully digital instrument cluster
10.25” Multimedia center display
4-speaker sound system(for weight reduction)
Safety & Security
Rearview and FrontCameras
ActiveBrake Assist
8 Standard air bags including driver and passenger knee air bags
PARKTRONIC®
AMG DYNAMIC SELECT
COMAND®Navigation
AMG Track Pace
Safety & Security
ActiveBrake Assist
PARKTRONIC®
#39
AMG GT R PRO
Feature
Mercedes-AMG GT R PRO
Bodystyles
Coupe
Optional Features
Exclusive NappaLeather
Optional, Nappa/DINAMICA Only
Lane Tracking Package
Optional (ForWeight)
AMG Dynamic Plus Package
Standard
AMG High Performance Ceramic Composite BrakingSystem
Standard
Standard Performance Features
Horsepower
577 hp@ 6,250 rpm
Torque
516 lb.-ft. @ 2,100-5,500 rpm
Top Speed
198 mph
Body design
Widebody, Carbon-fiber front fenders
Active Aerodynamics
AIRPANEL with Carbon Fiber Profile
Battery
Lithium Ion
15.4”F/14.2”R, Black Caliper
AMG Rear Differential Lock
Electronic
Manually Adjustable CoiloverSuspension
6-stageAdjustableRebound and Compression
AMG DYNAMIC SELECT
StandardGT R offering with RACE mode
RACESTART
Standard
Rear-Axle Steering
Standard
Traction control
AMG TRACTION CONTROL /w 9 Stages
2-stage,Titanium
Additional Details
AMG GTR PRO
Engine Configuration
Handcrafted AMG 4.0L V8 biturbowith dry-sump lubrication
Displacement (cc)
3.982
Acceleration 0-60mph (sec)
3.5
Fuel Economy (Cty/Hwy/Com)
TBD
Fuel Requirement (Octane)
91
# Valves per cylinder
4
Compression
9.5:1
Transmission
AMG SPEEDSHIFT® DCT 7-speed dual-clutch
Transmission Speeds
7
Drive Configuration
Rear-WheelDrive
Standard Tire Type
Michelin® Pilot Sport Cup 2 Tires
Fuel Tank Size (gallons)
19.8
Trunk Size (cubicfeet)
10.1
Curb Weight (lbs)
TBA
Vehicle Length (in.)
179
Vehicle Widthw/o mirrors (in.)
79.0
Vehicle Widthw/ mirrors (in.)
81.7
Vehicle Height (in.)
50.6
Wheelbase (in.)
103.5
Track Width Front/Rear (in.)
66.7/66.1
Coefficient ofDrag
TBA
Feature
Bodystyles
Coupe
Optional Features
Standard
Standard
Horsepower
577 hp@ 6,250 rpm
Torque
Top Speed
198 mph
Body design
Active Aerodynamics
Battery
Lithium Ion
Electronic
AMG DYNAMIC SELECT
RACESTART
Standard
Rear-Axle Steering
Standard
Traction control
2-stage,Titanium
Additional Details
AMG GTR PRO
Displacement (cc)
3.982
3.5
TBD
91
4
Compression
9.5:1
Transmission
Transmission Speeds
7
Drive Configuration
Rear-WheelDrive
Standard Tire Type
19.8
10.1
Curb Weight (lbs)
TBA
179
79.0
81.7
50.6
Wheelbase (in.)
103.5
66.7/66.1
Coefficient ofDrag
TBA
#40
991 gt3, GL350, X5 5.0 coming soon Mustang GT500, GTR PRO, GTR Black Series
Hi,
I am new to the forum. Today I was lucky enough to place my order on a new gtr pro. I had two on hold and one was sold a couple hours before I pulled the trigger. Both dealers had the colours/options already selected and locked in. I ended up with the matt silver combo.
It will be quite rare in Canada, only 35 of them coming up here and 150 confirmed for the States.
Now the wait
Now the wait
thebishman (02-21-2019)
#41
Back when the GT R Pro was announced, I contacted my main sales associate about getting an allocation. He mentioned that they didn't have MSRP information at the time, but figured the car would retail close to the $200,000 (USD) range before ADM. He got back to me a few weeks ago and mentioned he'd be able to get an allocation for around that price, which amounted to little to no ADM.
I ended up passing on it. For the price, I'd rather either wait for the GT Black Series or just get a Huracán EVO.
#42
Hi,
Now the wait
Now the wait
- DV2 - GT R PRO Edition
- B28 - Carbon Fiber Side Mirror Housings
- PAP - GT R PRO Edition
- U99 - Carbon Fiber Rear Fixed Wing
- 478 - Coilover suspension
- 5U9 - Crossbar - Carbon Fiber - Matte
- 773 - AMG Carbon Fiber Exterior Package
#43
did they give you a real PO #? there isnt a single one ordered (or at least allocated to a dealer) in the US yet..I just did a search.. Ive been begging for one with my rep
There is also no idea of when the car will be delivered but it is expected to be end of year at best but most likely March 2020.
#44
Huracan EVO is also 150K more up here.
#45
Update on the PRO in the uk.
DOG released at last, this is officially a non-specable car here.
all cars grey/green stripe and same options £188k
Cancelled my ordered. Back to Porsche for me.
#49
‘24 BMW iX M60
The market over here has been upended in many ways by the number of GT3s; GT3 RS' and GT2 RS' produced by Porsche for the 991.2 iteration. Many 'flippers' won't be making a killing this time due to the number of cars available. GT3 RS' apparently can be purchased for MSRP occasionally even now, and should potentially be sub-MSRP on the used market soon.
I have thought of getting a 991.2 GT3 RS but it just doesn't tick all of the DD boxes versus the GT R, even if it might be a little quicker on a road course, and of course to most people it's just another '911', whereas the AMG GT cars are still regarded as something somewhat 'special' due to their rarity.
Good luck with your search; let us know what you end up with as I'd love to see it.
Bish
#50
There’s a second batch coming that I may be able to get a slot for.
Porsche market here is softening because of supply and the B-word. Wouldn’t pay overs!
i also purchased a Schirmer M3 this year as well so I’ve options on all fronts really.
thebishman (03-18-2019)
