DashCam install
Looks similar to ours. The rear setup for the roadster is a bit more annoying but by placing it on the wind screen it records top and down.
Btw, you can easily hide the cable by the center console; the side leather trim can be just pulled and is only held by a clip. Simply pull horizontally away from the center console right where is the cable is...
Nice, I'll do that tomorrow so that it's completely hidden.
I'm not sure what you mean by "the A-Pillar runs the entire side". I popped all of the interior panels off, the the A-Pillar was a bit of a pain, and ran the wire down it, down the side of the glove compartment area.
I mounted my dashcam to the windshield, and my radar detector to the sun visor via a clip mount.
Coming down a pillar, cable would be tucked to this point.
How is everyone coming across here as it’s way to tight to tuck a cable?
And once down the side how best to go either behind carpet or back up next to underside of glovebox and down to fuse panel?
have done this before on my Yukon and other cars I had, just a bit hesitant as a busted trim piece for a merc is probably infinitely more expensive than for my Yukon to replace if busted 🤣
Give me a few hours and I'll pull it out, pop some of the trim, and snap a couple of pics.
These are the only pics I have on me atm from wiring in my front and rear dashcams.
I will soon be installing a DR900X with Cellink NEO in my GTR, so this stuff is of great interest.
I'd also be interested in hearing about how/where you got the power from ... and pictures, for the bonus points.
Otherwise everything is back to looking perfect and the install came out great!
