AutoTalent | Renntech Ecu+Turbo+Brake+Aero for Mercedes-benz Amg GT R 2018-2019
Old Oct 21, 2019 | 05:57 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. Our proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980s! Our experience, countless hours of in-house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicle's entire power band. By modifying ignition timing and throttle mapping, optimizing air-to-fuel ratios, increasing the engine's rev limiter and modifying boost mapping for turbo-charged vehicles, RennTech performance software unleashes the true potential of your Mercedes. With the proprietary RennTech ECU Tuning the C190 AMG GT R gains up to +50 HP and +73 LB-FT, based on power numbers measured by RennTech . Please note that the Mercedes M178 engine performance when measured, obtains higher numbers than rated from factory. The maximum power number reached with the RennTech ECU Upgrade for the AMG GT R is 659 HP and 614 LB-FT.
Features
Gains up to +50HP & +73LB-FT
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Stock Performance
577 HP @ 6,250rpm; 516 LB-FT @ 1,900-5,000rpm
609 HP @ 6,500rpm; 541 LB-FT @ 3,950rpm
Modified Performace
659 HP @ 6,150rpm; 614 LB-FT @ 4,450rpm
580 whp @ 6,800rpm; 540 wtq @ 5,600rpm
Renntech Performance Turbo Upgrade
Click HERE to order Stage 2 Turbo Upgrade!
The Mercedes GT is the second Mercedes Benz vehicle fully developed by AMG, the company’s Affalterbach based performance division and long fabled engine builder. The resulting vehicle is nothing short of spectacular and the 4.0L V8 BiTurbo engine within is an incredible platform to build performance upon. RennTech lightweight forged billet turbo wheels feature a dramatically larger than stock impeller (inlet side) and an increase in the turbine trim (exhaust side). This combination of high quality, light weight components compensates for turbo lag despite being a functionally larger turbo. The cartridge supporting shaft is also both larger and stronger designed to handle the larger wheels and additional power. This entire cartridge is then fine balanced as a complete assembly to compensate for these increases. The impeller and turbine housings are then precision CNC machined and flow tested in-house to fit the larger internal cartridge. The end result is nothing short of spectacular with the RennTech turbo package gaining up to 152 hp and 91 lb-ft. More power isn’t the only performance benefit as our turbos spool quicker, offer a more responsive throttle and immediate power delivery thanks to a reduction in exhaust back pressure, rolling resistance, higher RPM's and a lighter rotating mass. In addition, our turbo upgrade kit functions with the OEM oil and coolant lines. This isn’t just an OEM turbo charger with machined internals; but a dramatically larger, more powerful turbocharger that blows away anything else on the market. The RennTech performance turbo upgrade is truly the ultimate upgrade for your AMG GT R.
Features
The RennTech Stage II Turbo Upgrade comes with an RennTech ECU Upgrade.
Larger impeller (inlet) and turbine (exhaust) wheel
Entire cartridge is fine balanced as an assembly
Lightweight forged billet wheels
Less rolling resistance offers quicker spooling
Virtually no lag with impressive throttle response
Precision machined impeller and turbine housings
Up to 761 HP and 632 TQ @ crank
Gains: Up to +152HP | +91LB-FT
Stock Performance
577 HP @ 6,250rpm; 516 LB-FT @ 1,750-4,750rpm
609 HP @ 6,250rpm; 541 LB-FT @ 3,850-5,400rpm
Modified Performance
761 HP @ 6,800rpm; 632 LB-FT @ 5,600rpm
670 whp @ 6,800rpm; 556 wtq @ 5,600rpm
Renntech Aerodynamic Parts
Click HERE to order Carbon Front Canards!
Click HERE to order Carbon Rear Wing Lip!
Click HERE to order Carbon Rear Diffuser!
RennTech Front Canards was designed, engineered and tested in-house as a fully functional aerodynamic exterior upgrade for the AMG GT R. Its high-quality prepreg carbon fiber construction is finished in a beautiful gloss top coat to ensure years of durability and stunning good looks. RennTech front canards give AMG GT R an aggressive makeover. RennTech unique canards design not only looks menacing but also greatly improves airflow and front end downforce. Fit and finish meets OEM Mercedes-Benz quality standards thanks to the parts 100% pre-preg carbon fiber construction. The canards kit also features a unique acrylic coating process which protects the carbon fiber from any harmful UV and humidity degradation. This acrylic coating is applied inside and out to ensure full coverage and protection, unlike any other coating process. Once the acrylic coating is cured, the part is then covered using a high end automotive clear coat to create a beautiful gloss finish. The full kit consits of 4 dive planes. Two stacked pieces for each the driver and the passenger side. Canards are applied with double sided tape and can be removed without damage the paint or drilling into the bumper
Features
High-quality prepreg carbon fiber construction is finished
Offers a more aggressive, stand-out look
Durability and stunning good looks
Improves front end downforce
Greatly improves airflow
A beautiful gloss Finish
Perfect design
Renntech Performace Brake
Click HERE to order Carbon Fiber Brake Ducts!
Click HERE to order Brake Upgrade!
RennTech AMG GT R Brake Ducts are designed to improving brake performance during dynamic road and track driving. Significantly increasing the longevity of brake pads, rotors and calipers, the Brake Ducts are the first step toward a more powerful and efficient brake setup for the AMG GT R.
Whether your AMG GT R is equipped with iron or carbon ceramic rotors, the factory brake system is set up for everyday use and road driving. It is vital to understand that hard/spirited driving creates high temperatures around the brakes, which go far beyond everyday driving conditions. The function of the brake duct is to direct airflow to the center of the brake assembly, lowering the temperature of the brakes and lessening the possibility of brake fade.
In combination with RennTech performance Brake Pads, Brake Lines, Performance Brake Upgrade, and high-temperature brake fluid (600-degrees or higher), demanding drivers and track racers can build a street and track worthy brake system for their AMG GT R, which will save money, be safer, and make for an more inspiring driving experience.
Features
Left and Right Front Ducts
Left and Right Caliper Vane
Left and Right Rear Ducts
Heat treated for micro structure alignment and durability
Runout less than .0005 inches and thickness variation less than .0002 inches, reducing pulsation and vibration
Temperature range from 122deg – 1300deg (wide operating range)
Vanes turned OD and ID for balance to reduce thermal warping and vibration
48 vanes for superior thermal capacity
Surface finish less than .7 microns
Renntech Exhaust Valve Module
Click HERE to order Exhaust Valve Module!
RennTech plug & play EVM Exhaust Valve Module allows you to open the exhaust flaps of your car 100% at all times by pressing Button 1 on the remote control. If you wish to go back to factory settings simnply press Button 2. This gives you complete control over the exhaust sound and rumble of your car at any time regardless of speed, RPM or driving mode. The RennTech Exhaust Valve Module is made in Germany. If your car is equipped with factory exhaust flaps, with or without a center console button to open or close them, factory settings do not allow the flaps to fully open unless certain speed and/or RPM have been reached. For example, while cruising the exhaust flaps will never fully open.
Features
Software updates do not interfere with the functionality of the EVM exhaust valve module.
Activation completely independent regardless of drive mode
Override your cars factory exhaust flap setting with the push of a button.
EVM does not engage with CAN-Bus
No interference with any control units.
Plug and Play with original plugs
No cutting wires, no damage to factory cables, fully reversible.
1 x Exhaust Valve Module
2 x Remote Controls (Button 1 fully open, Button 2 back to factory)
Wiring harness (model specific)
Installation manual
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
