Went to the drag strip tonight
Old Nov 7, 2019 | 02:44 AM
dyc1077's Avatar
2004 sl600
I went to the drag strip for the first time in gts tonight. Sonoma raceway in northern California. I really should have figured out how to use race launch before getting there as I only got 1 successful run using the race launch. Not particularly fast and not happy with the 60 foot times. Car is totally stock 2016 amg gts in sport+ mode with race launch on oem tires. Here are the numbers for your reference.
60' - 2.071
330' - 5.259
660' - 7.793 @ 97.33
1000' - 9.969
ET 11.814 @ 122.16
Old Nov 7, 2019 | 07:17 AM
AMG 17GT's Avatar
R Nine T
We’ve talked about this before, but for me race launch was not effective in getting the car out of the hole, and it’s hard to engage at the line.
I went once, and my best was with ESC OFF, and feathering throttle from 1/2 to full throttle after about 1 second. 11.2/ 130.
if you can get 305 PS4s on there in back, probably a 11 flat for me.
Old Nov 7, 2019 | 09:35 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Not bad for a first track test. Get the 60 ft down to a 1.7 and you have a 11.2 ET ish.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 22, 2019 | 06:57 PM
CAracer's Avatar
GTS AMG
11.8@ 128 tune and tires 11.1 tune only
Old Nov 23, 2019 | 12:31 AM
dyc1077's Avatar
2004 sl600
tires made the car slower?
Old Nov 23, 2019 | 07:02 PM
CAracer's Avatar
GTS AMG
No, it should have been 10.8 @128.
