2016 GTs software update fail
back and forth as needed.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
anyone else have trouble updating the maps? Not really sure if it’s updating in the background but just not counting down but I figured an hour should be enough time for the update to complete. AppreciTr any input.
I'm supposed to go in and get mine done as its picky about the oil level and the electronic differential occasionally becomes unavailable. I have the tune from Eurocharged and the backup of the factory file.
When MB updates software, more often than not the update over writes all parameters.
When any tuner performs a tune, they are only modifying specific items (timing, boost, throttle opening, octane specific, top speed limiter removals, etc, etc.)
