Burmester speakers not working?
Dealer states the rear speaker is only engaged in "Surround" mode. So I put it in Surround mode and listened closely. Just getting a buzz from the speaker. Problem not fixed.
Asked them to address a display message to reduce oil level. The oil & filter was recently changed and apparently too much oil was added. Dealer informs me they can't drain off excess oil; that a fresh oil change was mandatory, per manufacturer. I scoffed and declined.
For the oil level issue and the speaker, both could have been diagnosed over the phone saving me a 45 mile drive to visit the dealer. Instead, they keep my car for two days and put me in a rental, only to return my car with none of the issues addressed.
I wonder if I should just tell them to flat out replace it or wait for diagnostics
https://www.burmester.de/en/Automoti...s-Benz/AMG-GT/
It’s 4 in the dash: 3 tweeters and 1 mid. The center console has 2 speakers with the upgraded Burmester.
I will check my sub - but it may be hard to tell if it’s working - the sub uses a lot of the car’s body as a cavity, so you’re not going to feel it vibrating.
The footwell speakers are the same... If you put your hand on them you likely won’t feel any vibration. That’s normal for low end drivers. Remember that vibration = distortion!
And the High End has special enclosures for the woofers: “To create optimum conditions for the woofers in the extremely rigid aluminum frame structure of the vehicle body, the frames are specifically sealed.”
Overall, the High End sounds incredible!
The sub is actually easy to tell if it’s working.
The woofers in the doors are harder to tell. But with your hand on the grills, especially the front lower part, you can feel a bit of pressure in time with the low notes.
You wouldn’t expect to feel much - again, vibration in the grill is bad, and it seems like Burmeister made steps to better isolate these woofers in the High End system. Plus, the sub and mid range are there, so these woofers are best called upper bass, which is not going to make a loud rumble.
is this the High End sub or the regular Burmeister sub?
https://www.burmester.de/en/Automotive/AMG-GT/
"High End 3D" System
"Surround" System
