Terrible Experience with 2020 AMG GTR Pro and AMG GT R Roadster
That being said, I would be extremely hesitant to replace anything on his two cars without it being OEM until these issues are resolved.
Bish
Bish
Just because the factory exhaust is titanium, it doesn't mean there aren't better options.
If MB lemons the car for just an exhaust rattle, it doesn't matter anyway.
Bish
The real takeaway from me - if you are thinking about buying an AMG GTR Pro - demand that you get to drive it prior to buying it, put the exhaust in performance/loud mode and it should be very obvious at low speeds, reverse and any type of acceleration that there is a clanking loud rattle. If it has it, DON'T BUY IT UNLESS YOU PLAN TO REPLACE THE EXHAUST! :-)
No, you shouldn't have to go outside MB to get something like this fixed, but dealer service departments are simply not trained, equipped, or allowed to "fix" things, rather they simply swap parts.
Otherwise, perhaps "GTR Pro and GT R Roadster, manufacturer buyback, coming to a Manheim auction near you!"
I doubt it happens though (unless he is already at the top of the list) as less then half of US dealers will get BS allocated to them and it will be 1 (one) car only regardless of how big the dealer is.
In your position it’s time to turn everything over to an attorney. MB can not Avoid working on the car just to stop breaching the LL criteria.
Good luck!
Bish
For those who aren’t familiar with the source of the problem it’s essentially a electrically operated box with a flap and springs made by a outside manufacturer.
In my opinion, the spring looses it’s strength/tension over time due to the exhaust heat and voila the rattle starts as the flap is moved by exhaust fumes.
THE FIX - A new box made better BUT in MB’s case the box is welded to the muffler. So, a whole new muffler is in order IF a better designed box has been found or made.
It’s essentially a plug and play item except for being welded to the muffler.
I am told the same vendor makes the same part for Porshe and others who have had their fair share of issues with it as well.
The more I think about it if I were you I would take the PRO to Renntech and let them put their exhaust flap box on it and be done with it.
Best Regards
Jerry
Best Regards
Jerry
Best Regards
Jerry
if you had researched the car thoroughly before buying you would not have spent $500k on essentially two identical cars. Personally , I would have gotten two different cars.
you expect perfection . It doesn’t exist. Is my $200k perfect? No. There are many cheap components in it but they are better than in my 40k Ford Edge ST. The Ford is reliable and does it job. The GT lets me go from point A to point B in style. At the end of the day it’s a machine with moving parts. Some rattle , hum or vibrate.
I don’t think you have ever owned a sports car let alone two GTs . I don’t buy it.
if you do have them , they are not the car for you. Mass transit or an Uber may be more fitting .
This isnt the first time Ive asked for you to show the softer side of your keyboard. Try it again especially when we are all subject to so much worse than just having car issues.
