Upgrading steering wheel
#51
Love the ASKCarbon wheels
So based on comments above, I understand that:
- All buttons on left hand side (cruise control) do not work?
- Lane Assist vibration function does not work?
- Comes with airbag but unclear if as effective as OEM in a collision?
- Made in China, not OEM replacement?
Am I correct - good to know before I order
#52
#53
#54
2. lane vibration is an added option can be done.
3. it included an OEM Mercedes airbag with Part #s (all genuine) they stressed this heavily . I even confirmed with my dealership.
4. they are customized in eupope and Asia depending on their stock and the job @ hand. They are made using OEM Mercedes AMG parts. So it’s not aftermarket. My steering wheel has the oem Benz logos and parts # just as my stock wheel had.
hope that helps!
#55
My car doesn't have lane assist. It was $1700 with the shift lights, and its plug and play with a new airbag other than one power wire for the shift lights I have to tap into. I was an EE so no biggie.
#57
I just got my new steering wheel and installed it (pics soon), The shift lights use a Bluetooth module that plugs into the ODB2 port. its about the size of a box of playing cards and trying to figure out where to hide it. anyone done this, I was going to pull the lower panel down above the pedals and see if I can zip tie it in there.
#60
Beast (07-19-2020)
#63
2020 McLaren 720s Spider
The wheel I got is the 2020 wheel modified with satin carbon and new switches/controls, and a new airbag. and the LED shift lights, its plug and play, You get the wheel, wheel switches (cruise, menu, phone etc) and new paddles.. took me about 30 minutes to install including the Bluetooth module for the shift lights (its an ODBII pass through) the hardest part was breaking the center Allen bolt lose on the original wheel. Long torque wrench did the trick with a 10mm Allen socket. Only thing I may change is getting matte switch plates, the gloss black are hard to read in the sun.
#64
its a great looking wheel. But one of the typical shortcomings on this upgrade is that the column has the controls for the cruise so unless you would replace the top of the steering column with this modification, the control buttons on the steering wheel itself, don't work. So, are you saying you found a way to get them to work? if so, what did you do - please share!
I'll try it tomorrow, but everything else works so I'd be surprised if it didn't.
#66
#67
Just installed cover and big aesthetic difference, especially with contrast stitching on leather. Props to mbjj57.
And big bonus was that after disconnecting battery for an hour, transmission reset and car a lot more responsive. I will probably do this a couple times a year.
can you elaborate on the transmission reset and responsiveness?
Ive got almost 13,000km on my car now. Will a reset improve transmission response?
#68
Transmission reset is easy to do. You don’t need to disconnect the battery
jn66 (07-19-2020)
#69
#70
just havent seen a video showing this modification on our cars yet - not sure if its possible. Side note - this one didnt require recoding.
#73
This, I'm so used to the stalk now anyways that it wouldn't bother me in the least.
