E30 Ethanol Blend
Has anyone tried this? What were your results?
I ran race fuel in my car for one rally, and it made a huge difference (car has downpipes and tune currently). Hoping an E30 mix can be a better solution to the $8/gallon race fuel.
If you don’t have an real world experience with our cars on using this mix, please don’t post. I’ll just ignore the “you’ll shoot your eye out” comments.
Did you baby your car after the accidental fill up or take advantage of it?
On another note, my tuner got back to me, and I’m now running E30 in the car. Going to give it a couple tanks for the car to learn everything then do some pulls on Dragy to see if there’s any noticeable difference.
This table is the high octane timing table with values pretty common on any NA V8. The region of the table highlighted is roughly the PE range after leaving closed loop.
The critical area for PE is in the range of 4K rpm to 6K rpm and with a spark air mass of approx, .80 to 1.00. The timing values in these cells optimize performance of 93 octane fuel in PE
Now if I seriously increase cylinder pressure under boost.
In PE, I am seriously reducing timing in the cells of the same range (but adding a spark air mass all the way out to 1.36) just to prevent spark knock. If I can increase octane past 93, in fact, all the way past 105 (with E85), I can come close to returning timing in the cells in the PE range to the original NA values. This makes for a whole bunch of performance. This comes with a warning - you cannot fill up especially with E85 if you're not tuned for it. A lot more to say here, but this would get unmanageably long.
