Lowering GTS with KW HAS help
Old Jan 19, 2021 | 06:39 PM
titus820's Avatar
2012 C63 AMG Edition1
Lowering the front and rear by 1 inch and with 15mm spacers front and rear. Anyone with this set up rubs?
Thank you in advance!
Old Jan 20, 2021 | 09:31 PM
kumizi's Avatar
Designo White AMG GTS
It wont rub with the HAS kit. I think 1 inch is the max drop.
edit: missed the part about spacers. I dont run spacers but have 315s on the rear instead of 295s.
Old Jan 20, 2021 | 10:35 PM
Skilly's Avatar
2020 McLaren 720s Spider
Im dropped about 30mm - more than an inch. The travel is still really comfortable and I love the look. Its access to driveways that become a problem with anything more than that. And really, Kumizi is right - an inch is the right call for max if you dont want to have to worry about uneven roadways.
Old Jan 21, 2021 | 01:00 AM
mbjj57's Avatar
amg gtc 2020 bk
What springs are you running on your GTC,
I believe the gts and gtc don't share the same "lowering springs"
Old Jan 21, 2021 | 10:59 AM
Skilly's Avatar
RENNtech adjustables.
Old Jan 21, 2021 | 05:05 PM
titus820's Avatar
Thank you all for your inputs!
Old Jan 28, 2021 | 10:50 PM
titus820's Avatar
Done! Dropped 1 inch front and rear with 15mm spacers front and rear. Loving the stance! Thanks for all the inputs!
Old Jan 29, 2021 | 11:34 AM
kumizi's Avatar
Looks good.
I didnt have problems with the front lip much but the underneath of the car would scrape all the time over large speed bumps. Raised mine up 1/3".
