DIY Oil Change and the Use Once Drain Plug
Old Jan 13, 2023 | 09:02 AM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
Originally Posted by descartesfool
How many litres come out when you vacuum the tank, and then how much comes out the sump drain plug just to know how much to put back in. Do you warm up the oil first to the specified temperature for the coolant?
I've done this. a whole lot less messy.
I drain it from the top, then remove the screw from the bottom. You get about another 2-3 ounces more from the bottom.
Old Jan 14, 2023 | 04:15 PM
Bitcoin's Avatar
AMG GTS
Appreciate this! Have you ever found the oil on the dipstick to be near the low, but still get the 'oil overflow' issue?
I'm having this issue right now...
