2016 GTS, E85 anyone?
Old Apr 26, 2021 | 12:49 PM
Bijan Kohan's Avatar
2016 GTS; 2021 G63; 2015 Range Rover Supercharged
Hello all,
I have had my 2016 GTS for almost 3 years now, bought it as a CPO back in 2018 with less than 6k miles on it.
Performance wise, I’ve installed:
Catless DPs
Pure Turbos stage 2
Upgraded Spark Plugs
Go Labworks tune with handheld
My tuner is telling me that to unlock the power from the pure turbos without having to use 100 octane race gas, I can have a HPFP installed, recommending Xtreme DI, and he can send me a new map to be able to use E85 pump gas, and gain very good HP and torque numbers.
Has anyone done this? Your thoughts? Thanks.
Old Apr 26, 2021 | 02:33 PM
corn26's Avatar
2020 E63S
My understanding is you need an upgraded fuel pump to run full e85
Old Apr 26, 2021 | 02:37 PM
Correct. By “HPFP” I meant high pressure fuel pump.
Old Apr 26, 2021 | 02:39 PM
corn26's Avatar
2020 E63S
What about LPFP? I have seen a few eurocharged vehicles running both e85 and blended fuels on the internet. Never saw one in person though haha. But people have definitely run full e85 on their amg gts. But wow your car is gonna be insanely fast haha
Old Apr 26, 2021 | 09:10 PM
kumizi's Avatar
Designo White AMG GTS
You can make over 700whp on 93 octane. If you need more power than that, you can go the E85 route. The transmission starts to become the weak point at those power levels.
Old Apr 26, 2021 | 10:08 PM
Unfortunately in California we don’t have 93 and the highest we have is 91 and due to this limitation my car is making just under 600 whp. That is why I’m going this route so that I can comfortably make high numbers. There is a E85 station few minutes from my home and cost is only $2.70 per gallon.
Old Apr 27, 2021 | 12:38 AM
kumizi's Avatar
Oh yeah I remember your old thread. E85 idea would work but I'd figure out what's wrong with your car before throwing more money at it. It should make a lot more power than it is. Find a local tuner.
Old Apr 27, 2021 | 01:43 AM
Yes! I’m still dealing with the same issue. I was going to take my car to another dyno where I got all my mods installed, SSR Motorsport and have them dyno tune my car with my tuner, go Labworx, but every-time I ask both of them they blame it on the crappy 91 fuel. That’s why I decided to go this route but you have a point.
Old Apr 27, 2021 | 08:59 AM
realien's Avatar
2016 AMG GTS
I ran E85 on my Nissan GTR and it had a flex-fuel monitor on it that fed the ECU software and adjusted boost, timing, etc based on octane content. The issue a lot of the Nissan guys had (but I never had it in 2 years of ownership) was the E85 eating seals. One of my buddies had a bad misfire issue, which turned out to be an injector o-ring that had dissolved. I did a tank of 93 ever 4th fill up, to get the detergents and less corrosive fill up.
I'd be interested to hear how well the GTS tolerates E85 over the long term, but I do continue to be surprised at people wanting such high HP in a RWD car, I run 93 and have downpipes and a tune and the back end likes to get wiggly at full throttle...
Old Apr 27, 2021 | 11:56 AM
You’re right, I still have the stock tires and to say they least they do not do well under WOT. I will be looking at tire upgrades as soon as I’m done with the power upgrades. I never open up the car from a start. I always wait till I’m going at least 30mph or in 2nd gear.
I have no idea why Mercedes didn’t use their 4matic AWD system on these cars. Ridiculous.
Old Apr 27, 2021 | 01:02 PM
Hetzle's Avatar
2016 AMG GT-S
I would guess due to weight - the car would be likely near 4,000lbs if added.
Regarding your turbos, are they the Pure 900's? I've been considering getting a set just so I can enjoy a full power band all the way to redline.
Old Apr 27, 2021 | 01:12 PM
I wouldn’t mind the added weight with AWD any day.
Yes I have the 900’s, stage 2. I would definitely recommend against it unless you have access to 93 octane daily. With 91 the tune is too conservative and does not add barely any power versus just catless DP and tune. That’s why I’m going the HPFP route so I can use e85.
Old Apr 27, 2021 | 04:37 PM
Hetzle's Avatar
2016 AMG GT-S
Hmm thanks for the info...I wouldn't expect the difference between 91 and 93 to be so huge. Are you still around 560whp?
Old Apr 27, 2021 | 04:55 PM
I did a dyno over a year ago and was at around 590 Whp. I was told that I should have been around 650. I need to dyno time my car either way. I thought the HPFP and e85 tune would seal the deal.
Old Apr 27, 2021 | 08:26 PM
Hetzle's Avatar
2016 AMG GT-S
Ah ok 590whp on 91 isn't too far off 650whp on 93, given the potential differences between dynos and engines.
E85 should make a BIG difference - I'd guess 25-50% depending on how aggressive of a tune you decide on. Best of luck with the build, I'll be watching excitedly
Old Apr 28, 2021 | 12:23 PM
kumizi's Avatar
315/30/18 Toyo R888R
I was making 700whp and it dead hooked in 2nd gear on a sunny 70 degree day.
Old Apr 28, 2021 | 12:24 PM
kumizi's Avatar
If you have the bigger Pure 1000 Turbos, you can make 800whp easy on E85.
Old Apr 28, 2021 | 05:00 PM
Maxbrotha's Avatar
AMG GT-S
Transmission start slipping around 800whp?
Old Apr 28, 2021 | 05:46 PM
kumizi's Avatar
Definitely likely if you race it at that power level. Dodson does make a clutch pack for these cars now.
Old Apr 29, 2021 | 12:42 AM
Yes I do have the stage 2 pure Turbos. 800 WHP sounds very exciting!
Is R888R the way to go? Can you easily drive with these? Are they terrible in the rain? It barely rains here in LA anyway. Can you go with 325’s in the rear? Thanks in advance.
Old Apr 29, 2021 | 03:04 PM
Hetzle's Avatar
2016 AMG GT-S
My car is lowered and I am running 325's in the rear, but Michelin PS4S (those R888R might run wider or smaller) and I do rub a very minor amount over large bumps at speed.
Old Apr 29, 2021 | 05:10 PM
kumizi's Avatar
There's no benefit to going with 325s on stock wheels. 315/30/20. R888R is louder, not good in the rain, wont last long, and follows grooves in the road. But it's the best bet if you want any traction.
Old Apr 30, 2021 | 04:04 AM
Wont 325 in the rear five you more traction versus the narrower stock tires?
which tire do you recommend which is much stickier that stock tires but is not that noisy and does ok in rainy weather?
Old May 1, 2021 | 08:03 PM
kumizi's Avatar
If you actually want traction with 700+hp, you have no other option. The R888R is still a big improvement over the old days where you had to run a drag radial that felt like you were going to die every time you had to take a turn. It's a little noisy and dont drive over 60mph in the pouring rain.
Old May 23, 2021 | 07:50 AM
0ptimoprime's Avatar
16 AMG GTS
outside of the turbo's themselves what other supporting mods are needed for that turbo upgrade? or are they truely just a bolt on and tune deal.
