Amg gtr replacement battery
Old Jul 8, 2021 | 09:25 PM
drscottmcf's Avatar
2018 amg gtr
Angry Amg gtr replacement battery
Can you let me know how much a replacement battery for a 2018 AMG GTR should be.
My local dealer is saying it will cost almost 3000 dollars.
Also the reason it needs replaced there is a fault coming up on the dash. The car has had no difficulties starting at all. This seems to be an intermittent fault. Could leads need to be tightened, They also said i will need to replace the alternator for another 3000. Any suggestions?
Thanks in advance
Scott
Old Jul 8, 2021 | 09:36 PM
AMG 17GT's Avatar
R Nine T
Where is your local dealer?
Old Jul 8, 2021 | 10:35 PM
57 GTR's Avatar
2018 Diamond White GT-R
What are they doing ,pulling the engine to change the alternator? What fault is coming up on the dash? How many miles? There are a bunch of good minds on this forum,tell us/them more so maybe it can be solved for less than 6K
Car Battery Replacement Estimate for Mercedes-Benz AMG GT
Mercedes-Benz AMG GT Car Battery Replacement costs $301 on average.
Car Service Estimate Shop/Dealer Price 2019 Mercedes-Benz AMG GTV8-4.0L Turbo Car Battery Replacement $518.49 $635.52 - $958.69 2017 Mercedes-Benz AMG GTV8-4.0L Turbo Car Battery Replacement $498.49 $615.53 - $938.72 2021 Mercedes-Benz AMG GTV8-4.0L Turbo Car Battery Replacement $498.49 $615.53 - $938.72 2018 Mercedes-Benz AMG GTV8-4.0L Turbo Car Battery Replacement $498.49 $615.51 - $938.68 2020 Mercedes-Benz AMG GTV8-4.0L Turbo Car Battery Replacement $498.49 $615.55 - $938.75
Old Jul 9, 2021 | 10:30 AM
thebishman's Avatar
‘24 BMW iX M60
Get a high quality OBD II reader and find out what exact fault is causing the CEL.
Also, if your car is starting fine I doubt the Li battery is the culprit. Put it on the supplied charger and fully charge over a couple of days. Then clear the fault with the OBD II reader and see if it reoccurs.
Are you not still under warranty? If so an alternator replacement would be a warranty item. However I doubt there’s anything wrong with it either.
Some owners have electrical gremlins caused by a chaffed wire in the loom in the left rear compartment. I would check there, and find a new dealer to care for my car.
Bish
Old Jul 9, 2021 | 11:06 AM
JSwan724's Avatar
2024 AMG G63 2025 Ferrari SF90 AF Spider
Thanks in advance
Scott
Go to another dealer and get a 2nd opinion. Request an estimate before repair.
Also, as other posters suggested, see if you are still under the factory warranty and/or a CPO.
Also, DO NOT SHARE THE CURRENT DEALER ASSESSMENT WITH THE 2ND DEALER. Just tell them the problem and let then determine the solution.
Good luck.
Old Jul 9, 2021 | 12:20 PM
BurtReynolds's Avatar
AMG GT Black Series
The lithium ion battery is meant to last the life of the vehicle unless not maintained. They are expensive, I don't have the info in front of me, but it was over $2k for the battery plus install. Do not use a regular trickle charger on your GTR as it requires a Lithium Ion specific charger.
Old Jul 9, 2021 | 08:08 PM
LAsunset's Avatar
Fast and Really Fast Sports Cars
What's with this info? And, the V8 engine probably costs $1,080.78 to replace at Walmart.
Old Jul 11, 2021 | 01:05 AM
roadtalontsi's Avatar
10 C six trizzle
There's a few different battery sizes, mostly around $1500 list. alternator list around $1400. that's parts cost only. battery replacement will require some programming/coding so more difficult than few screws to replace but not $1500 labor worth. Alternator probably 4-5hrs of labor, but I have never done one. Typical dealership overcharging.
Old Feb 11, 2022 | 07:10 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
Mercedes of Delrey is offering their AMG for $50k over right now.
Old Feb 12, 2022 | 12:59 AM
mbjj57's Avatar
amg gtc 2020 bk
Thanks in advance
Scott
run away
it should be under warranty though
Old Feb 12, 2022 | 03:37 AM
57 GTR's Avatar
Originally Posted by mbjj57
run away
You're answering a 7-month-old thread and he has 1 post, lol
