Help with Removal of Inner Trim Cover in Trunk
In an ironic plot twist, the gnarly adhesive of the 'protective' blue plastic wrap applied by the factory to this AMG logo'd trim piece has significantly marred said piece (i believe it is MB Part #: 1907203402)
Using plastic pry tools and leverage from different angles, etc still does not get this piece to yield for removal, and any additional force will likely break it.
You'll need to remove the side panels.Then you will find 2 Torx screw next to the "plastic banana" on top of the cover.(I believe T 25)Do not try to remove the "plastic banana".It's not working.In the middle of the AMG cover there is also a glued / Velcro-fastened spacer.
Kind regards.
Stenzel
Trim piece is actually a rubber-ized plastic, and sans any metallic overlay. Mild citrus oil cleaners and other solvents were used (Goo Gone, etc) to no avail. The plastic is F*-ed
