oil drain copper crush washer size/part number?
Old Sep 19, 2021 | 04:11 PM
enjracing's Avatar
2017 AMG GTS
was wrapping up changing the oil when i realized that i have misplaced the copper crush washer. what is the size of that or a part number so that i can order one on amazon and avoid a 30 min drive to the dealer. thanks guys.
Old Sep 19, 2021 | 04:23 PM
Hendrik Koster's Avatar
Top Answer: 1
2007 S65 AMG-Sold, 2007 SL55 P030 - 2016 GL450 - - 2017 AMG GTS - Sold - 2015 AMG S65
If you have the old copper washer, aneal it > place the washer on a metal hook, hold it in flame (gas stove or torch) until it is red hot, ones it red hot let it slide/fall of the hook into a small container with cold water.
Now the copper will be soft and pliable (you can bend it with your fingers) and reuse it on the oil plug where it will make a perfect seal.
No need to get a replacement.
Best H
Old Sep 19, 2021 | 04:50 PM
chassis's Avatar
2017 GLE350 4MATIC
The washers are formed. They bend when being “crushed”. Annealing will not restore a bent, aka crushed, drain pan washer. Mbepc or mbparts.mbusa.com will help find the part number.
