Fixing the Center Console Glove Box Door on the GTx
Old Feb 27, 2022 | 07:15 PM
G. P's Avatar
2020 AMG GTC
A bit late, but this may help as a very simple and quick solution. I did it about 2 years ago and it's still working.
Just glue 2 x 1/4" rubber hole grommet O ring washers (or similar) to the rear of the center console box, between the back hinges. This will provide enough pressure to pop-up the door.
These are still available on Amazon as a $12 Kit:
Amazon.com: Wolfride 180Pcs Rubber Grommet Assortment Kit Rubber Hole Grommet O Ring Washer Set Rubber Wire Grommets| 1/4 Amazon.com: Wolfride 180Pcs Rubber Grommet Assortment Kit Rubber Hole Grommet O Ring Washer Set Rubber Wire Grommets| 1/4", 5/16", 3/8", 7/16", 1/2", 5/8", 7/8", 1" : Industrial & Scientific
Old Sep 15, 2022 | 06:29 PM
lgarcia's Avatar
2016 AMG GTS Edition 1
These rubber grommets work like a charm! I will find some other use for the rest of the grommets but for $12 it fixed my problem quick and easy. I used a drop super glue gel under the grommets. Thanks!
Old Nov 29, 2022 | 06:26 PM
jflick's Avatar
2020 GT C, 2020 GLE 450, 2019 CLS 450 AMG
GTC Console Door Now Opening Perfectly
Just installed the black spring pins(via EBay from Greece) and the console door now pops open perfectly. Prior to putting in these spring pins the door just did not open when I hit the release. Then, inevitable while driving down the road I was fiddling to get the console open, usually with both hands!!! If you order the black pins do plan on waiting a month or so for these pins to show up from Greece. Also, the shipper had a signature requirement which was not really necessary, and that added a day or so. Thanks so much for this tutorial on solving a minor, but vexing problem on my GT.
Old Oct 25, 2025 | 05:34 PM
deltaplus's Avatar
+1 for the rubber grommets above! Works like a charm - I didn't even have to glue them in, I just placed them there and the closing force of the door keeps them stuck. I'll eventually make them permanent with a drop of super glue, but it's night and day and such a cheap fix!
Old Oct 31, 2025 | 10:31 PM
G. P's Avatar
2020 AMG GTC
I'm glad it worked for you. Simplicity at its best.
