do lowering springs actually improve handling?
Old Dec 3, 2021 | 02:39 PM
magnogts's Avatar
amg gts
I dont find the handling of the stock gts bad at all, maybe a bit of roll on the rear. I am uk based and we have pretty poor quality roads here and the most useable roads are b roads so ideally i need something compliant, not too stiff, not too soft.
I really want to lose that hideous arch gap but am terrified of making the car handle worse. What makes it an issue for me is changing the springs isn't like a normal car, much more work to fit and then messing about with shims for alignment. Not a quick and easy way of messing about with settings.
I have read so many different posts and there seems to be a circle of kw is better than h&r but renntech is better than both, but then i have actually read a couple of comments saying the renntech ruined the handling.....poor geometry perhaps?
The renntech also i believe have softer springs on the rear and stiffer on the front. As opposed to slightly stiffer all round for kw. I find that odd why a third party would totally change the dynamic of the rates as opposed to stock.
Im not masivley concerned about comfort as such, i just want as good or better handling and to sit a bit lower.
Spacers as well? part of me thinks that wont help handling at all, do any of you use cars on track with spacers?
Such a shame that the car is that awesome but the wheels sit too far in the arch and the arch is abut 6ft off the ground.
Old Dec 3, 2021 | 03:20 PM
AMG 17GT's Avatar
R Nine T
Renntech coilovers are more compliant all around. To me, it’s the perfect stiffness when lowered 1 1/2 “. Car used to be an oversprung pogo stick.
Handling wise, car stays flatter and faster in corners, especially in rear.
Whatever you do, I suggest you opt for adjustability and stay away from Fixed Springs, as you will no doubt fiddle to get the right height for you. GL
Old Dec 5, 2021 | 04:12 AM
magnogts's Avatar
amg gts
Thanks, its just a shame that removal and refitting of springs on these is so complicated as opposed to a 'normal' car.
In the past if i didn't like something on another car its been easy to just remove, sell and then replace. My last car was a tvr tuscan which was like a lego kit
What makes it worse is the state of the roads here in the uk They are definitely not race track quality is all i can say
Old Dec 5, 2021 | 11:46 AM
Acta_Non_Verba's Avatar
Bentley Continental GT; AMG GT
My primary attraction to this platform is because it is not normal......LOL....
