Jack point
Amg Gtr Pro
Jack point
Hello all. In need of some more advice. How do I take off the cover for the center jack point for a GTR Pro? The cover has a central opening that looks like a rivet. An allen wrench doesn’t work. Is there another jack point for the vehicle? Thanks as always.
That's not a jack point. The jack point is actually slightly behind that opening, there's rectangular hole in the frame which you could stick in one of these: https://reverselogic.ecwid.com/Jack-...W251-p21543971
then it can be used as a single jack point to lift one side of the vehicle. Otherwise, you'll need to use the side jack points which are located slightly behind the front wheels and in front of the rear wears (covered by a rounded black rubber pad).
Check this thread Where do a place Jack stands? - Page 2 - MBWorld.org Forums
Also highly recommended jack adapter to use:
Amg Gtr Pro
