Question for anyone who has installed GT4 wing on GTR
Old Aug 10, 2022 | 11:33 AM
Y.Haider's Avatar
2015 Mercedes S550 Coupe
Do u use the same bolts that are on the current GTR wing?
Pic is of the gt4 wing from youtube.. just making sure i have everything needed to mount the GT4 wing on my GTR
Old Aug 12, 2022 | 12:39 PM
MG1422's Avatar
GTR
I used different bolts than the stock ones for GT4 wing angle adjustment
Old Aug 14, 2022 | 02:05 AM
Y.Haider's Avatar
could you give me info on what size bolts? Did the stock bolts not fit the gt4 wing?
Old Sep 23, 2022 | 05:09 PM
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
i’m trying to install mine now. not quite getting how this works on factory mounts like I had heard.
Old Sep 25, 2022 | 09:00 AM
Y.Haider's Avatar
you will need to open the trim from inside the hatch and remove the stock GTR wing mounts and replace them with the mount that came with the gt4 wing
Old Sep 25, 2022 | 12:29 PM
dllhg's Avatar
your car looks amazing. what front splitter is that ?
I realized I didn’t get the GT4 mounts.
Luckily friend ordered same wing and i can use his and they will ship the new ones to him 👍
Old Sep 26, 2022 | 09:29 AM
Y.Haider's Avatar
Yeah u will need the mounts..
front splitter is from amazon.. not proud to say that but couldnt find anything else for it at the time
Get the renntech diffuser extension.. makes a huge difference in how the car looks
Old Oct 1, 2022 | 10:47 AM
dllhg's Avatar
so i got the lower mounts. Now i can’t get the deck lid piece off. removed the 16 nuts. it moves a little but won’t pop out no matter what I do. is there adhesive or something ? need to heat up perhaps ?
Old Oct 1, 2022 | 10:57 AM
Y.Haider's Avatar
I believe there is adhesive there.
Old Oct 1, 2022 | 01:51 PM
dllhg's Avatar
makes sense. heat gun or hair dryer maybe ?
Tikt got back to me confirmed there is adhesive tape on the outer edge.
Old Oct 2, 2022 | 07:46 AM
Y.Haider's Avatar
Yeah heat gun did the trick for me
Once u have the base off theres 2 screws on each end to take old mounts off which u will need to replace with longer screws for the new mount
was a pretty simple job
Old Oct 2, 2022 | 01:08 PM
dllhg's Avatar
I ended up using a blade on the left and right as per TIKT recommendation worked pretty well. I wish I had known there was a left and right lower bracket. Had to redo the whole job. They look nearly identical. Second time around took me exactly 40 minutes start to finish so i’m really good at it now. 😂
Old Apr 5, 2024 | 09:24 AM
xxxPaulxxx's Avatar
2020 AMG GT C Roadster
if intrested..I could offer a new GT4 wing
