Exhaust Burble problem
Old Oct 11, 2022 | 06:10 PM
Hhccc1's Avatar
gtr
Greetings, I have recently bought a 2018 Amg Gtr.
I have a minor question but it is pretty strange which maybe could be a bigger underlying problem. The problem is that the car's exhaust burbling sound actually varies time to time. When I first got the car, it seems to burble a lot, now I feel like it's more softened. The car were all in working temperature and at same gear and rpms when comparing. The only difference is that I have installed the renntech valve control, and I don't believe that is the problem. Could what gas is used be a factor?
Thank you
Old Oct 11, 2022 | 06:48 PM
MalibuScott's Avatar
2025 Lucid Air Grand Touring, 2022 F-150, 1926 Rolls-Royce SSG roadster
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” ~ Sir Arthur Conan Doyle, The Case-Book of Sherlock Holmes.
Old Oct 11, 2022 | 08:23 PM
W205C43PFL's Avatar
Thank you
I would say scan for codes if there might be stored soft codes but you did say there are burbles just reduced instead of completely no burbles. Although you mentioned the rennetch valve control not having to do with it, did you try unplugging it and restoring to stock at least for a couple of drives?
Old Oct 11, 2022 | 10:10 PM
Skilly's Avatar
2020 McLaren 720s Spider
Thank you
Fuel would play a part in that. Also, make sure you are in the right mode - it will only "burble" in Sport+ and Race. The sound is exhaust gas igniting post compression in the exhaust...
Old Oct 12, 2022 | 02:17 AM
Y.Haider's Avatar
2015 Mercedes S550 Coupe
Make sure the valve control is functional and valves are actually open
Old Oct 12, 2022 | 03:13 AM
AndrewFerg's Avatar
AMG GT C Edition 50
Thank you
Everyone is being polite. It's likely the valve control - unless you don't understand the driving modes. Drive it in Race mode with manual shifting and allow compression braking at higher RPMs. There must be pops as the post ignition is guaranteed. If the valves are closed erroneously, there would still be pops but just quieter.
Old Oct 13, 2022 | 02:05 AM
mjr24's Avatar
M6 Gran Coupe
Thank you
Is it possible the previous owner drove it like he stole it and you don't....and the ECU has relearned your driving (which may be less aggressive and therefore less pops/burbles)? Maybe reset the ECU?
Old Oct 14, 2022 | 09:04 AM
UCIMBZ's Avatar
E55, 380SL, GLA 250 Sport, AMG GTS
Stuck flap.
Old Oct 15, 2022 | 01:00 PM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
The flap opening logic is not simple and not just open or closed. See the thread I started about this recently.
Old Oct 24, 2022 | 02:58 PM
dav461's Avatar
GTR
mine does burble in Sport as well as in other modes. fl gtr
Old Oct 24, 2022 | 03:24 PM
Skilly's Avatar
Not if its a stock it doesn't.
Old Oct 24, 2022 | 06:03 PM
Y.Haider's Avatar
My GTR flaps open on sport+ and race mode only
Old Oct 24, 2022 | 07:33 PM
Skilly's Avatar
Correct in terms of an auto setting but with your exhaust button you can open them in C or S too. It still wont creating that popping effect. though.
The "Burbles" are timing adjustments (retardation) where a small amount of unused fuel escapes to the exhaust chamber and ignites. That sound/happening is reserved for S+ and R settings only.
