Transmission Leak
Old Nov 21, 2022 | 08:43 PM
Orcbolg's Avatar
AMG
Transmission Leak
This pertain to the extension MB applied to the warranty on the Transmission, specifically for leaks.
Had just pulled the car out to run some errands, and had to run back inside to grab something. Glad I did, as I found a massive puddle of transmission fluid. I called up my local MB dealer and they towed the car in. They later called to confirm the updated warranty extension on the transmission, and got authorization for a covered transmission replacement.
Two weeks later and my car has a new tranny, with an estimate for $18k, and warranty covered invoice.
2016 AMG GTS with 27k miles - car had been sitting in the garage for 4 or 5 days, previous to finding the puddle, with no transmission issues present pre-puddle.
Old Nov 22, 2022 | 06:31 PM
LAsunset's Avatar
Fast and Really Fast Sports Cars
Damn. This is not good. Any idea where it was leaking from?
Old Nov 22, 2022 | 10:29 PM
JMalanox's Avatar
AMG GTS
Had the same issue few months ago on my 2016 gts, it was covered under the extended transmission warranty. 😬
Old Nov 22, 2022 | 11:30 PM
Orcbolg's Avatar
AMG
Must be an internal issue, as this is all they described in the workup:
"ISOLATED LEAK TO SEEP HOLE OF REAR TRANSMISSION. NECESSARY TO REPLACE TRANMISSIONCOMPLETE"
Apparently MB won't do any repairs on the transmission, only full replacements.
Here's to hoping that the new transmissions don't suffer the same date in the future.
Old Jun 14, 2024 | 04:23 PM
Ricobryan's Avatar
AMG GTS
Can anyone update on if you need MB warranty in order to get a replacements or is this something they replace without extended warranty on the vehicle?
Old Jun 14, 2024 | 08:42 PM
Orcbolg's Avatar
AMG
I believe the original transmission warranty extension is now over, and MB would no longer cover the replacement cost.
Old Sep 13, 2024 | 09:29 AM
Fattcj7's Avatar
E55
I can fix these transmissions for much less than the dealer. I can provide references. im not sure if there is a private message function on this forum...if there is then pm me if interested... otherwise post and we can talk somehow.
