Oil change two drain plugs?
Hey all, I'm looking to change the oil on my 2016 AMG GTS. I know there are two drain plugs. A plastic one which is under beside the tires and another one that has a washer to it.
Does anyone have the part number to the one that has a washer to it or does that not need to be changed? (see attached image below)
Thank you
Thank you
I just did my oil change as well. Plug doesnt need to be replaced (assuming its not damaged or stripped). Just replace the crush washer. I got a 15 pack on amazon for $8. Look for part # 007603-014106.
Walmart Parking (05-08-2023)
