Check Engine Light on highway
Hope you are all well!
Earlier today, I was on the highway and had an issue after I stepped on the accelerator pedal. I actually gave it close to full throttle, and almost immediately, in 4th gear, the car started slowing down, the left side of the car was shaking, and it felt like it had lost power.
The car was shaking every time my foot was on the accelerator. I stopped and gave the car a cycle, which made the issue and check engine light go away. I am calling my service advisor first thing in the morning, but do let me know if any of you have experienced a similar situation or if you know what it could be.
MB has an extended warranty on coil packs for this car up to 15 years if i recall correctly (got a letter about this a year ago). Mine is a 2018 GTC Roadster and my service guy at MB identified the coils of 2 cylinders being the culprit. They swapped them out at no cost.
Few weeks later (I rarely drive these days) the same thing happened again. Same cylinders. This time they ruled the coil packs out and went through a whole laundry list of diagnostics and tests. This time it was a bit difference, as the check engine light went off by itself (it didn't do this in the first go around).
They couldn't find anything wrong with the car and knowing that I don't drive a lot and the car has about 10K miles they assumed that it might be old/bad gas and an injector issue. So they filled up the tank and poured some injector cleaning in.
Now I'm just driving it through a couple of tanks with cleaner and we will see if it occurs again.
Hope that helps.
They detected misfiring on one cylinder, had the coil and spark plug replaced for it, and the car is running smoothly once again with no signs of misfires or running rough.
If you experience a misfire like this, it may get gradually worse over time. Get it looked at and sorted ASAP.
Let me know if you have any questions!
Best,
Best,
