Got a misfire problem
I have a problem with misfires in cylinder 6 and 8. The car runs perfectly in all ways with no engine light BUT if I push the pedal to the floor for full power it will throw a code at high rpms. Car will then run rough till I restart it and then the light will sometimes go out and other times stay on but the rough engine will go away on the re start and all will work as expected till I nail it again.
MY scanner shows misfires for cylinder 8 during two computer resets and a cylinder 6 after another reset. I am wanting to switch the ignition coils and I am guessing 6 and 8 are on the same coil. After switching the coils i will see if the misfire moves cylinders.
With that said my version of wis is not longer working so if someone could tell me where cylinder 6 and 8 are in the engine diagram????
Katie
Katie
