20' AMG GT R WONT START
I have no idea what Mercedes was thinking when they decided to not allow consumers to go into neutral.
Good luck.
If engine not Cranking. Unfortunately There is only ONE way to get AMG GT in Neutral without building hydraulic pressure on the transmission .You Need CUT A HOLE (I m not joking) in upper Middle Right side of your trunk then rip off the noise damper cover of the transmission. then you will see a Mechanical Neutral spine Pin. Another unfortunate MB did not give you any lever or socket you can put it on to turn it. You can try use vise grip but not ideal. Better get the lever from Ferrari .
Pic showed from Ferrari Parts Diagram. Lever P/N 238370 GOOD LUCK, Don't ask me why I know this.
LOL
