GTR Pro feedback Laguna seca Video
I only track the car 5 or 6 times per year. I've come from a McLaren 600LT which ate discs and pads for fun. I was going through CCB pads in 2 days and CCB discs in 8…there's no cooling to the brakes!
The side equipped with the Tikt system was significantly cooler than the side with nothing.
I then installed a homemade aluminum system on the passenger side, and the Tikt system was much warmer.
Next, I compared the Ansix with my aluminum scoop, and the temperatures were similar.
The advantage of the Ansix is that it’s made of plastic, so if it breaks, it won’t damage your car.
However, you need to be careful with the balancing weights; there shouldn’t be any on the inner side of the rim, otherwise, they’ll hit the scoop.
The Tikt system is less efficient than the Ansix, by about 50°C.
