CCB brake noise
IMO, the biggest issue with track use of CCBs is the fact that the only truly accurate way to measure their "wear" (i..e, chemical degradation due to heat) is via the very expensive Carboteq tool (assuming you have the rotors with the applicable markings).
Funny thing is that I find the "pad plating" on the rotors gets wiped off at the next track day so now I just live with some noise. I find that the brakes are quiet when cold or "track hot" but there's an "in-between temp" where they'll squeal a bit. It's been postulated that one can tell when grandpa's "been naughty" by the squealing brakes when he approaches the driveway after a "keep it lubed" drive. #;-))
CCBs are brilliant on a street car. The rotors will last the life of the car as long as you’re careful changing out wheels and replace the pads when they’re 2/3rds worn, and they keep the wheels so much cleaner than with iron rotors. Plus since they’re always larger than a set of irons, they add to the looks of the vehicle imho. As we’ve discussed here though, they do need at least a ‘Street burnish’ in order to enhance their cold stopping ability and decrease any noise.
Iron rotors are better on track for ‘track adicts’ in that it is far cheaper to replace an iron rotor than a CCB one, along with the pads being cheaper and the huge amount of ‘brake dust’ isn’t an issue. On track braking performance, (as it always is) is dependent on the tyres, and if the iron brakes are well designed with adequate cooling, their performance characteristics will not reduce with prolonged use. This is why most highly experienced; (meaning quick) HPDE drivers will tend to gravitate towards iron brakes. Oh, and since most iron rotors are less diameter than their CCB counterparts you can run smaller wheels which gives you far greater and cheaper choices for tyres.
Caveat: if you only go to the track about 3-4 times/year and are cognizant of how to minimise the risks of wearing out a set of CCB rotors, then they are also fine to use at an HPDE. Also, if you don’t give a damn about costs, then again, just run the CCBs if you want.
I would love if AMG sold their calipers with plating or anodizing. I got rid of the bronze gold paint and had my calipers painted in black.
While I grant you that the current 3rd(?) generation of CCBs are far more durable than previous generations, you still have to be extremely cautious not to overheat them and accelerate oxidation. Brake cooling and early replacement of pads is paramount.
That being said: ‘track rats’ who go to a road course many, many times per year will routinely replace the OEM caliper/rotor setup with a true track worthy ‘BBK’ such as one from AP Racing, regardless of whether the car came with CCBs or iron rotors.
WIS has specs on the allowable chips and other wear/damage, similar to the radial-hole cracks with iron rotors.
I worry more about chipping the edge of a CCB rotor when removing/installing wheels, especially with the minimal clearance on the front wheels. One needs to be very careful and steady. Personally, I raise to the appropriate height with my hoist then use my shop stool (with pneumatic
seat-height adjuster) to carefully "wheel the wheel" into position.
IMO, if you have CCB rotors, you _always_ want to "photo before" then check their condition before leaving the shop if any service involved removing your wheel(s).
CCB rotors are extremely hard. One forum member has reported that the CCB rotor surface bore no scratches after accidentally depleting the pad and hitting the metal backing. I accidentally did that on my C63 S with iron rotors and, while it still stopped surprisingly well (!!!), it did seriously score the iron rotor surfaces.
You're correct that heat management becomes much more valuable with CCB rotors, since it's the heat that wears them out. That's why I invested in the TiKT brake-cooling ducts before tracking the car.
https://rebrakeusa.com/the-process
This is NOT an "oops I got them hot once and now they're scrap" type of thing. Our local track is _very_ hard on brakes so my front rotors are likely regularly hitting 500+ deg C (I measured over 650 deg C on my C63 S's iron rotors when I did a quick stop to check tire-tread temps, with no cool-down). I record the readings from my Carboteq tool after every track day and they wearing very well. I love the fact that they're so unflappable with zero brake fade, etc.
BTW, on a somewhat related side note, are you aware that the EU is considering legislation to ban carbon fiber due to the hazardous dust it produces during disposal? It's becoming the new asbestos. That'll be interesting for brake etc. technology in the future.
