Time for exhaust actuator.
Old Jun 1, 2025 | 11:05 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Got to he code and sure enough #2 actuator was barely moving. By hand valve is free, so ordered new actuator.
ps actuator has a magnet stuck to the spring with the nuts that hold on actuator.
you do have to remove rear bottom panel and loosen exhaust hangers so you can pull down system an inch to get access to nuts for actuator.
Old Jun 4, 2025 | 07:42 AM
Katie22's Avatar
Important update. If you have to replace one of these you simply install if and then it will automatically find its travel limits.
Old Jun 6, 2025 | 04:18 PM
silvergs's Avatar
AMG GTs
I hope this works for you. Unfortunately it wasn’t really the problem for me. The code was the actuator, but really it was a stuck exhaust valve that throws the car into low power mode. Check out my trials and tribulations
summary , bought new valves, had them welded in place or old ones and zero issues since.
https://mbworld.org/forums/coupe-roa...lve-fixed.html
Old Feb 21, 2026 | 11:01 AM
knowbenz's Avatar
Benz
Where did you source replacement flap to weld in place? My GTR is having the same issue
Old Feb 21, 2026 | 11:44 AM
Katie22's Avatar
I believe I got it aftermarket on Amazon for about 200 dollars. I realize it’s not OEm but it’s easy enough to change so I went with this and it works good.
Old Feb 21, 2026 | 11:46 AM
knowbenz's Avatar
Benz
got it, I found some 2.5" on EBay, I just have to verify size of pipe and mount for motor. The replacement muffler is almost $6k last I checked so welding in an aftermarket unit is fine with me
Old Feb 22, 2026 | 06:51 PM
silvergs's Avatar
AMG GTs
hey bro hope this helps.
I purchased beefy ones because I only want to do this once
https://thermalrd.com/search?q=helic...prefix%5D=last
cost 250 a pop and let me tell you, you can feel the smoothness, quality and beefiness
simple cut and weld
not the cleanest weld job but here
