Engine oil level does not display
Old Nov 28, 2025 | 01:22 AM
Roschned's Avatar
Amg Gts c190
Recently did an oil service, where later that day i got a “reduce oil level” so i did and wanted to check the oil level…
Here is my problem: I want to see the oil level - but it does not appear in my service menu. My menu ends with "coolant". My menu will not scroll down any further.
i have seen people accesing it on pre-facelift gts models. I have a facelift. The one with digital clusters.
ofcourse i have a traditional dipstick, but shouldnt the car display the oil level?
Old Nov 28, 2025 | 10:58 AM
G. P's Avatar
2020 AMG GTC
Depending on the exact model year of your car, the steps to access the “Workshop” menu can vary.
The procedure in the link below is for a facelift 2020 GTC, but it may work for your car as well:
https://mbworld.org/forums/coupe-roa...ml#post9087364
Once you’re in the Workshop menu, use the guidance in this post to view and monitor the oil level:
https://mbworld.org/forums/coupe-roa...cking-oil.html
Just remember that the displayed oil level will only be accurate once the engine oil temperature reaches approximately 200°F (93°C).
Regardless of the above. Dipstick is the way to go (still at 200F), see this comment: https://mbworld.org/forums/coupe-roa...ml#post9232686
