GTC Spool Performance
Just one correction: you stated the car makes 843 WHP. The Dynojet sheet shows 843 horsepower at the engine (crank). With the Dynojet set to its default 15% driveline loss, that equates to approximately 716 WHP. Still very impressive power for a GTC.
Can you share what benefits you’re aiming to achieve by increasing horsepower and torque to this level? Do you track the car, and if so, what type of tracks? Or is the car primarily used for street or daily driving?
At a minimum, this would require a Dodson DMS-8184/8185 clutch kit and a PTG 7DCL750 AMG GT billet brace system—if not additional upgrades—simply to reduce the risk of transaxle damage.
In a perfect world you’d like the torque to come in earlier and then maintain a nice flat line across rpm range, and pull out that higher rpm little spike which would LOWER the peak torque number a little but have more of it in useful areas like powering out of a low speed 3rd gear corner……can always overcome by dropping another gear and throwing it into the power band a bit more if you want to work that hard!
At these torque levels, usage matters more than the number itself. You can run 1,100 lb-ft for a very long time if torque application and shift strategy are disciplined and the driver understands load management.
Conversely, a few aggressive launches, poor shift timing, or repeated clutch shock events can destroy the driveline almost immediately.
At this level, on a transaxle that was designed for 550ft-lb, reliability is a narrow window that’s defined by how the torque is applied, not just how much of it there is.
At the end of the day, at that number I wouldn’t stress too much unless launching the car with boost built. If he’s tracking the car on circuit I’d worry even less, and he will know if/when a clutch pack upgrade is needed if he ever sees the dreaded RPM wobble from clutch slip.
I still remember your excellent posts from 2024, where we discussed the PTG 1000, its capability and how to effectively manage and shape the torque peak.
https://mbworld.org/forums/coupe-roa...000-hp-tq.html
Fuel used in this setup is e40 on Spool Pumps. Bumped up to e50 and added a low pressure upgrade and car made 900 wheel horsepower.
Based on the dyno image you shared, that appears to be how the results were presented.
