Brake fluid reservoir sensor wire
This is exactly what I needed. The other end was tucked well under the larger wire. Only had about 1 inch to work with but was able to make the repair. You saved me an expensive trip to the shop!
Did you end up soldering or crimping? Quite the tight space.
