A GTR has landed in my garage!
Old May 20, 2026 | 04:14 PM
  #51
Kevin#34's Avatar
AMG GTR 2021 (Euro version)
I definitely have to try that—thanks for the tip. I'll let you know how it goes!
Originally Posted by thebishman
Here is what Chat-GPT states to do for the 2018-2020 GTR:Procedure:
  1. Bring the car to a complete stop on level ground.
  2. Keep your foot firmly on the brake pedal.
  3. Start the engine.
  4. Move the E-SELECT shifter to Neutral (“N”).
  5. Release the foot brake.
  6. Switch the ignition OFF.
  7. Leave the key/fob inside the vehicle.
  8. Exit the car carefully without pressing Park.
Ensure the car is ‘chocked’ or otherwise secured against rolling of course
Old May 20, 2026 | 04:15 PM
  #52
W205C43PFL's Avatar
Originally Posted by Kevin#34
Exactly, it would be really handy if I could move the car just a little bit forward or backward, so I wouldn't have to start the engine every time just for 10 or 15 seconds.
Did you try the other forum member's method and see if you are able to put it in neutral?
Old May 20, 2026 | 04:18 PM
  #53
Kevin#34's Avatar
Another thing I haven't been able to do yet, despite several attempts, is access the secret menu where you can view the temperature and oil level (someone here on the forum posted the exact procedure, complete with photos)... Either I'm doing the sequence wrong, or maybe the feature is disabled on European versions (though that wouldn't make much sense)
Old May 20, 2026 | 04:51 PM
  #54
superswiss's Avatar
2019 C63CS
Do you mean the workshop menu? I did the attached write up a while back for my Indy to retract the rear pistons. This should work on the FL GT as well. They didn't know about it. You have to make sure the ignition is in the correct position and that you are on the correct screen for the trip computer. Also make sure you press the correct buttons on the steering wheel. They are different between cars with DISTRONIC and w/o DISTRONIC. I don't think you can see the oil level, though in the GT. Like my C63, the GT still has a physical dipstick instead of an electronic oil level sensor, and the temperatures you can see w/o the workshop menu. I've got them up most of the time as shown in the picture below. All the temperatures together with the tire pressure are shown in this one view.
File Type: pdf
Old May 20, 2026 | 04:53 PM
  #55
Kevin#34's Avatar
not yet, but will try it (I'll be away from the car for 2 weeks)
Old May 20, 2026 | 05:01 PM
  #56
Kevin#34's Avatar
I can confirm that mine has Distronic, and—as I suspect is the case with all C190/R190 models—it also has the dipstick for checking the oil level, and of course the engine oil temperature is displayed on the instrument panel. I wonder if, by following your code combination, I can bring up the workshop menu on mine too...
Old May 20, 2026 | 05:09 PM
  #57
W205C43PFL's Avatar
Sounds good, to answer your other question, car has NTG 5.5 right? so same as forum member superswiss.
Old May 21, 2026 | 06:42 AM
  #58
Kevin#34's Avatar
yes, NGT 5.5... I’ll try the method he suggested
Old May 21, 2026 | 06:50 AM
  #59
W205C43PFL's Avatar
yes, NGT 5.5
Forum member superswiss' method should successfully get you in the workshop menu then.
Old May 28, 2026 | 09:30 AM
  #60
Kevin#34's Avatar
Hi everyone, I just bought the LED bulbs to replace the factory halogen ones in the interior reading lights, and I was wondering if I could do the same with the ones on the sun visors...
