How do I make it black again???
How do I do to make this "supposed to be black" plastic beeing black again??
Thanks in advance!
Good luck.
Cheers!
Mix some simple green and water in a spray bottle (50/50) mix. Soak the wheelwells(that is the name for it) with the mixture thouroughly, let stand about 10 minutes, then respray the area and scrub with a slightly rough bristled tire brush and then rinse. This should clean the area, then follow up with your favorite plastic protectant if you like. I recommend taking off the wheels and tires to do this.
) but I think I let the wheels stay on. Thanks again!
For plastic protectant use Armorall, use lots of it, that should get it black.
