Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
caliper paint
Old Jun 10, 2005 | 12:40 AM
2quik's Avatar
caliper paint
i want to paint my calipers, what do you guys recommend i use , and where do i buy the caliper paint from
Old Jun 10, 2005 | 08:48 PM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
caliper paint...
2quick,
i painted the calipers on my 2000 vett with a high-heat spray paint from pep-boyz, and it had brake calipers written on the can for applications.
I had to get a garb bag and tape up everything i didn't want any spray on (really not too hard).
there's also a brush on paint - google it.
aceman
Old Jun 11, 2005 | 02:26 PM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Callipers:
A way to spice up the look and at the same time protects the callipers from corrosion.
The Calliper Paint System features aircraft quality paint, available in six different high gloss colours, Red, Yellow, Blue, Silver, Black, & Purple. The paint is heat resistant up to 932 degrees; this paint won't start running into your brake pads, it also seals and protects against corrosion.
Brake dust and dirt will not adhere to the calliper surface since adding the paint. The kit includes everything you'll need to get the job done, besides paint you'll also get reactor (special bonding agent), high tech calliper cleaner, mixing sticks, and a brush
[http://wheelskin.com/Merchant2/merch...CALIPER+PAINT]
JonM
