Best Wax
#51
Zaino Fan!
Originally Posted by moa4r
agreed. took me about 4-5 hours to do the whole process. start off with dawn, claybar, z7 wash. then, 2 coats of Z2, 2 coats of z5 (all with zfx) with a single coat of z6 in between every coat of z2 and z5. The stuff really is amazing.
#55
Not to interject a supercilious question -- but would it help if you had your 115 lb girlfriend jump on the hood of the car nekid in a fur coat in between any of those coats and thrash around on her back like a monkey in heat? 'Cause I've always wondered (and maybe if you said yes I could print it out and qoute it to her 'cause I keep asking her and she says that it's a silly idea, but I tell her no, Honey I'm serious - it's a good idea - it will really help to lay down a smooth high sheen layer before the next coat which is the whole idea behind this coat)....
You lost me with the sixth interim coat of Xenon XG109....I take mine to a detailer!
Originally Posted by revstriker
Just one thing to point out: You should reverse the order of Z5 and Z2. Z5 will fill any swirl marks, but it does not shine as well as Z2. Once any swirl marks have been filled to your satisfaction, you should switch to Z2. You should always use Z2 as your finish coat (not including Z6 or Z8).
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
#56
Originally Posted by ClayJ
Not to interject a supercilious question -- but would it help if you had your 115 lb girlfriend jump on the hood of the car nekid in a fur coat in between any of those coats and thrash around on her back like a monkey in heat? 'Cause I've always wondered (and maybe if you said yes I could print it out and qoute it to her 'cause I keep asking her and she says that it's a silly idea, but I tell her no, Honey I'm serious - it's a good idea - it will really help to lay down a smooth high sheen layer before the next coat which is the whole idea behind this coat).... ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#58
E-240 2000 , E-240 2001 , CLS350 2006
i still can't understand how can you people know that the wax is not there any more i mean can you say that the car need to be waxed now and how can i remove the wax if i can't see it. when do you need to wax again and how the wax help to protect the car. i face the same problem in removing any kind of dirt on the car weither it was waxed or not . can any one clear out these points . by the way i alwayse use clay bar to clean the paint then wax with NXT .
#59
'03 Yukon XL Denali, '06 Eclipse GS
If you need/want to strip existing wax, wash the car with Dawn dish soap.
#61
No need to remove existing wax if applying the same. If you are a Zaino user or using another product over the existing coat, that's when it's ideal to strip the existing wax with detergent to begin a fresh new coat.
Claying strips wax anyway, so I doubt you'll have to worry about washing with Dawn.
#62
do i have to remove the wax everytime i want to wax, or should i leave the old wax layer and just apply over it . what is better ?
As for claying, I really don't think you need to clay your car that often (unless you show your car). I normally clay my car when I first bring it home, and then again maybe 18-24 months later. I do strip my car (using a Dawn Wash) and apply 3 coats of Zaino about once a year though. Whatever kind of product you are using, if you are not getting the type of deep shine that you once got, you might want to think about stripping and starting over.
Also, don't get confused between the terms "Polish" and "Wax". Often times they are used to mean the same thing, but they are very different. The basic difference is that polish normally has an abrasive compound in it. There are exceptions to this such as Zaino which calls itself a polish but is really not.
For the most part, you can wax over a polish, but not the other way around. Zaino of course is an exception as it's made to be used independently.
#63
mercedes c class avantagarde se (sport pack)
Ive always used Zymol since taking delivery of my car, ive tried megueirs but find it doesnt give the same type of shine!
Heres some pics , freshly waxed using zymol concours wax . P***ed off as once it was finished it rained on the car
#64
2001 E220cdi ,2004 E500
the determeting factor for the cars shine isn´t the wax,it´s the ground work before it. if you polish your car god the shine will be there no mather wich brand you use
#66
BLACK 05 C230SS
#70
2004 E55
Originally Posted by bert3enz
Yo! you guy are all hypin up Zaino wax, but i can't find it anywhere.. where can you purchase Zaino wax??
#71
2008 Porsche 997 C4S Cabriolet
First Time Zaino User
Just used Zaino for the first time last week. I'd have to say I like the product. Rather easy to use and the results look even better in person.
JS
JS
