Whats Better Liquid or paste wax?
By the way i am going to be purcasing Zaino products soon and i am wondering are there polishes liquid or paste?
carnuaba paste waxes usually last longer than their liquid counterparts. Zaino is a liquid but it is not a "wax" it is a paint sealant. 2 coats of Zaino should last around 4-6 months.
Does it give the same protectant as a wax? if u use 2 coats of Zaino is it correct that i dont need to wax my car ever if i keep using Zaino every 2 months?
thanks
2 coats right away. I mean after i did the whole car with one coat. i do the whole thing over with a seconed coat? or do i wait a day?
thanks
Also i was intrested in getting Z2 how many coast should i do of that?
so if i use the Zaino i will not need to ever use wax? does it give the same protection as wax would, like against the sun?
. Nope, no need for wax if you have Zaino. Zaino is a paint sealant, its basically a wax that chemically bonds to your paint instead of just floating on top of you paint like a carnuaba wax, this is why Zaino has such excellent durability. This is actually the reason u must remove all waxes with a dawn wash before using Zaino, so the Zaino can bond to bare paint. Zaino gives much better protection against sun damage than regular wax, it is actually equivialant to SPF 40 i believe. You can check their sight www.zainobros.com for more info on that. For a black car i would get both Z5 and Z2. Those pics in the thread i post "flawless black paint" that was only with 3 coats of Z5/ZFX. I plan to top it with Z2 as it is more "optically clear" and provides a higher gloss. For me my goal is 3 Z5/ZFX and 3 coats of Z2.
I am pretty lucky and i dont have many swirl marks on my car so should i still use the Z5?
Also on my silver CLK is it ok to just use the Z5 forever.
Sorry for all the questions i just dont want to do anything wrong.
My cars always looked good with just the Meguairs gold calss wax but i am hoping the Zaino will make it look better and keep it prtected better.
Thanks for your help.
Sorry for asking so many questions the reason i ask is because if i buy the Zaino i will not buy anything else again (like wax) so for my black car i should use use Z5 and Z2. in which order? Z5 first then Z2? and do i need to wait after i take the Z5 off to put the Z2 on? Or do it right after?
. I would order both, some people prefer Z5 on black some prefer Z2. I like Z2 because of that extra gloss it gives over the "deepness" of Z5. Sal Zaino always recommends your last coat to be Z2 because of its better optical clarity, so on silver i would definitely use Z2. I would use Z5 first and then Z2, see which you like better, this is also the order they recommend on the zaino website. Yes u do need to wait 24 hours after taking Z5 off to Z2 unless u have used ZFX. Z2 Z3 and Z5 are all the same paint sealant except, Z3 is Z2 with special additives to help non clearcoated finishes and Z5 is Z2 with an agent that helps fills swirls marks. Z5 however does provide a slightly different look on black than Z2, Therefore I recommend you get both and experiment! Please post pics and your results! Thanks!
hehe no problem dude, I am here to answer your questions
Also before i apply the Zaino can i use any dishwashing soap or does dawn do anything special?
But in the mean time till i order it and it gets here, back to the question about the meguairs #9 swirl remover if i just put it on and once its dry wipe it off and dont put a coat of wax over it is that still helpful? or does it not serve a purpose without wax on top of it.
Thanks alot for your help, thanks to u when i'm done my car will look better than new.
Get some Zaino Z-6 also. Use it between coats of Z-5/Z-2. It makes the finish appear deeper. Z-6 is a great quick detailer for clean light dirt between washes. I carry a bottle and micro fiber cloths to clean up bird droppings, bug splats etc.
Thanks alot for your help. It will definitly come in handy and when i'm done i will definitly post pics.
just one thing u did not really answer if i use the #9 Swirl remover and do not put a coat of wax over it, is it still help full?
thanks
