Zaino Z2 or Z5???
Zaino Z2 or Z5???
this is probably not the room for this topic, but i'm looking to get an answer quickly...
I'm applying zaino for the first time and wondering which one to use? Just washed the car with dawn liquid soap. Both bottle says "car polish", so i'm a bit confuse
I do notice the Z5 says removes swirls and the Z2 doesnt say anything...
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
06 CLS55
out of all the waxes that I used this by far was the best. I used the z7 and it worked great. It was extremely confusing to use but if you go on their website you can find insgtructions on how to apply them.
Good luck!
Clos
Good luck!
Clos
06 CLS55
I think the difference is in the time between coats of wax. Since I purchased the z7 it had an accelerator that allowed me to add another coat with out having to wait an hour.
they also had a difference in the fact that one was more abrasive than the other. IU would test it in a small area before you decide which one to use.
Have you gone on their site. I know they have a customer service number that you can call where they will tell you how to apply it.
Clos
Clos
Originally Posted by Kar don
u cant apply Z2 or Z5 without ZFX or Z1, and this is moving to the detailing forum.
thanks for your response and sorry for the post. needed some fast advice... i went ahead and applied z5. Cant really tell since its night time, have to wait until tommorow morning to see if zaino did the job.
As always, you must use Z1 before either Z5 or Z2. You can eliminate the need for Z1 by adding the ZFX accelerator to the Z5/Z2. Also, if you are using the Z1 with the Z5/Z2, you have to wait 12-24 hours between each coat. With the ZFX, you do not have to wait, and can apply up to 3 coats in one 24 hour period.
Good luck!
Clos
Good luck!
Clos
Originally Posted by BlackCard
I have heard Dish Washing Liquid is for washing dishes only! They have a tendancy to be harsh and strip off wax.
Ajay![devil](https://mbworld.org/forums/images/smilies/devil.gif)
Ajay
Originally Posted by revstriker
If you did not apply either Z1, or add the ZFX to the Z5, then it will not cure properly, will not give you a great finish, and will not last very long. You did not mention buying either of these products, so I hope you just forgot to mention it. Otherwise, you should take a few minutes and read through the instructions and the product descriptions on the Zainostore website. It will save you time and money.
dammit! I do have zfx... What should i do now, since i've applied z5 already? Should i take another crack at it with zfx? You also mentioned z5 only hide and not take away scratches or swirl marks. Can you provide me with some instructions to completely remove scratches and swirls? The instructions on zainos website is a bit confusing and I dont remember seeing detail steps.
thanks again for your response!
In order to remove swirl marks, you need a polish or a compound that is abrasive. This will actually remove a fine layer of the finish. Normally this can be accomplished using a random orbital buffer. For deeper swirl marks, a step up to a rotary buffer will help. If these don't help, then you would need to move on to wet sanding. Just to note, all of these techniques can cause damage to your finish (some more easily than others) if done by someone who does not know what they are doing. For more information on these techniques, check out some of the "sticky" threads within this forum.
As far as I know, Zaino products are all non-abrasive, so you cannot remove swirl marks, or scratches with these products.
You mentioned (I think) that you had purchased a Clay Bar as well. If you haven't used this yet, now would be a perfect time, right after the dawn wash, and right before the Z2 or Z5 (with ZFX). You can do damage to your finish with a clay bar, so please do read the instructions on the Zainostore website before trying this out. It's pretty easy to to this correctly, so you should not be scared of trying it.
ouch... another wash and wax
I think i'll get a professional to do this, as the only tool I have is my left hand and right hand ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
But seriously, you were planning on putting another coat on anyway, so how hard would it be to give it a quick wash first?
As for professional help, this is a good idea if your swirl marks are bad. But if they are light (normal), a few coats of Z5 should hide them well.
Anyway, best of luck to you. As payment for this advice
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
just made an appointment with a local detailer. I heard a lot of good things about them, besides they had mostly high end cars when i came by today. ferrari, mercedes, bmw etc... the guy did mentioned i need a buffer machine to properly get the swirls out.
anyways, thanks for your help. I think once these guys get rid of the swirls, I can manage to maintain a good shine with zaino. I'll post some pictures tomorrow.
thanks!
thanks!
just an update. The detailer did a great job on the swirls, but wasnt very happy with the shine. I ended up applying Z2 a week after the detail job and man.... am i happy. Z2 by far is the best i've used so far. Z5 didnt do much for me.
By the way, would it make any difference if Z2 is applied again?
....the guy did mentioned i need a buffer machine to properly get the swirls out.
If you used the ZFX added to the Z2, you can apply up to 3 coats within a 24 hour period. If you did not use the ZFX and applied a coat of Z1 first, then you have to wait 12-24 hours in between each coat (each coat will need to cure). If you did not use ZFX or Z1, well, then, see above.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Well, you can get them out with hand wet sanding.... but a buffer would be my first choice. Zaino will only hide the swirls, not remove them.
• Safely removes minor scratches, swirls, oxidation, wax buildup and other blemishes
• Features the world's first true self-dissolving, fused tri-particulate, diminishing abrasive system
• 100% compatibility with all painted surfaces and Zaino paint products
• Water-based formula means no mess, no staining, and easy clean up - no fillers or oils
• Can be used in sun or shade on cool surfaces
• VOC compliant
• Perfect your paint with Zaino Z-PC Fusion
• VOC compliant
• VOC compliant
Originally Posted by NdnMbLova
C43 have you tried this fusion yet?
