Questions about Nappa leather care
Should be cleaned by brushing the nap with a soft nylon upholstery brush, remove pilling with a single-sided razor blade and then applying a cleaning solution (Water /Woolite® or Dreft® with a ratio of 5:1 or stronger) on to an applicator pad and apply to one area at a time (do not soak the fabric) Localized stains can be treated with a citrus-based cleaner, ensure surface is dry before use by leaving window cracked/open. For heavy stain removal- 1:1 Folex Instant Carpet Spot Remover / Distilled water- http://www.folexcompany.com/
Identifying characteristics- very soft to the touch will scratch or scuff very easily; water drops will darken the leather but it returns to its original colour after drying.
Maintenance- Use a soft brush lightly to remove dust and raise the fabrics nap, once your seats / steering wheel / interior is clean, you should use a conditioning/protection product (303™ High Tech Fabric Guard, which includes UVR protection)
