wood trim and dash
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Trim cleaning:
The interior trim consists of the dash, vents, hard plastic surfaces and vinyl trim. These surfaces all can be cleaned using a damp Microfiber towel and a 5:1 Woolite / distilled water solution and with a water-based, anti-static cleaner that contains UVR protection (Iz einszett ****pit Premium For all plastic surfaces (BTI Chemicals Plexus® Plastic Polish & Cleaner) including wood, as they are protected with a urethane clear coat
Simply apply a small amount of product to damp Microfiber cloth and apply to surface, then buff with a dry Microfiber cloth, usually a small section at a time. Agitate with assorted interior detailing brushes and wipe excess moisture with a terry towel.
Repeat this process on all plastic and vinyl surfaces. Some panels that are heavily soiled may require several cleaning steps to reach desired level. After applying products allow drying and then wiping all surfaces with a damp towel. The wood trim in most vehicles (Mercedes Benz uses real wood) is protected with a urethane clear coat, polyurethane or a thin lacquer, which is very easily scratched. Remove scratches with a fine polish (Groit's Fine Hand Polish) clean /protect with a chemical cleaner (Klasse All-In-One) and then buff with a clean 100% cotton towel.
Maintenance- use an anti-static plastic cleaner (BTI™ Chemicals Plexus Plastic Polish & Cleaner)
