Menzerna PO106FF and Mercedes ceramic clear coats
The new PF106FF Ceramic Clear Coat Polish is an exciting product from Menzerna, which continuously supplies the detailing world with the highest quality products. To understand this product, you first have to understand the mentality of Menzerna product developers. Menzerna meets and exceeds the ISO 9001 standards, which are the most stringent in the world, through a strong commitment to quality control. They strive to provide the most well balanced products that get fantastic results with every use. Each product must excel across the board at its designed function and anything less is unacceptable. Their obsessive refinement has produced one of the most technologically advanced products in detailing.
The PF106FF Clear Coat Ceramic Polish was designed to give users light to medium cutting power without leaving any haze behind, so it can be a one step polish. Typically, polishes that have medium to heavy cutting power use strong abrasive particles that can leave a slight haze in the clear coat. This haze is essentially the surface still being slightly jagged at a microscopic level. To remove this jagged appearance use a lighter polish that has smaller abrasive particles, so the surface can be buffed even smoother. This is a similar concept to using aggressive sandpaper followed by finer grit sandpaper to further smooth out the surface.
The PO106FF makes polishing even the hardest clear coats quick and easy with exceptional results. PO106FF uses the finest sized abrasive particle in polishes today, but added a higher concentration of abrasive particles. This new formula has more cutting power while the finer sized particles allow you to buff the clear coat even smoother. The ability of this product to reduce surface imperfections and leave the surface extremely smooth is critical to a deep shine. A smooth clear coat with minimal imperfections allows for light to pass directly through, thus creating a deep shine. A smooth clear coat will allow a wax or sealant to adhere to the clear coat better, resulting in a longer lasting shine and protection.
I recently used this product with a white polishing pad from Lake Country Manufacturing and the Porter Cable 7424 at speed five. Going into the detail, I was looking for serious cutting power that would also leave no haze behind on the surface at the same time. I was able to spread the product over the clear coat and buff it in with no problems. I took my time exerting medium pressure on the buffer and carefully moved over the clear coat in a systematic manner. When I thoroughly buffed the product in there was only a thin, almost clear, layer of polish left that I hand removed with a microfiber towel. There was some slight dusting but it was all removed with relative ease. The next step was to inspect the cutting power and shine. The cutting power was stronger than I expected coming very close to the power of a medium cutting polish, with no haze to be seen. However, the most impressive part was definitely the deep shine beaming from the paint. The paint gave off a mirror like shine that was extremely smooth to the touch. My expectations were very high going into the detail, and Menzerna’s PF106FF proved to be a superior polish. I recommend the PF106FF to anyone who wants to remove light to medium swirls and get a great shine in one step.
I hope you found this information helpful and informative. This article is similar to the content found in our newsletter if you'd like to read more like this sign up here. The newsletter also has exclusive sales offers and update you on current specials and contests. Let me know if you have any questions or comments.
Greg @ Detailed Image
For anyone considering the PO106FF I know it seems like a big investment because its not a cheap polish but I think it really winds up being a good investment compared to other polishes that get similar results. I broke down the costs here assuming each coat takes 3 ounces:
PO106FF $49.99
$49.99/32oz = $1.56/oz
$1.56/oz x 3oz per coat = $4.68 for one coat
If you use the Menzerna Intensive Polish and Final Polish II here are the costs:
Mezerna Intensive Polish and Final Polish II are $15.99 each
$15.99/16oz = $1 per ounce
$1/oz x 3 ounces = $3 per coat
$3 per coat x 2 coats = $6 per application.
Most importantly the PO106FF requires only one coat so you're getting a better finish, for less money in less time. I think this is the product of choice if you really want great results from polishing.
