Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Cleaning Plastic Window
Old May 4, 2007 | 05:45 PM
BRUCE BRADLEY's Avatar
Looking for a suggestion for the best solution for maintaining and cleaning the plastic R129 roadster windows with minimum scratching.
Old May 4, 2007 | 06:23 PM
Greg@DI's Avatar
To avoid adding very fine scratches I'd recommend cleaning it with paint safe materials like a sheepskin wash mitt and drying them with microfiber towels. Using old mitts, sponges and towels will increase the chances you'll add fine scratches. You can further protect the plastic by applying a sealant to them. Just like applying a sealant to the paint, it forces moisture to bead up and roll off the plastic. It also helps prevent abrasions and damage from other contaminates. You can use the Rain Clear Gel or other traditional sealants. Before applying these sealants you should confirm they are okay to apply on that particular kind of plastic. Generally they are fine on plastics but it's always better to be on the safe side. Let me know if you have any other questions.
Greg @ Detailed Image
Old May 8, 2007 | 09:11 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
`Soft Top' Rear window (vinyl) –wipe with a damp waffle weave towel, or a Glass Master ™; apply a plastic cleaner (Z-14 Plastic Magic Cleaner & Polish™ or BTI Chemicals Plexus® Glass Polish & Cleaner) that is safe for all types of clear and coloured plastics, Perspex, Lucite, Mylar (window tinting) and clear acrylics. Wipe the plastic with a damp Microfiber towel afterwards to break the static charge. Plastic tends to build up a lot of static electricity, which will attract dust to your newly cleaned lenses. This simple, easy to use product cleans, brightens and protects even the dullest headlights, also works great on taillights, the plastic windows in convertible tops, instrument panels, and motorcycle windscreens .P/N DA2030- Shine Restorer Protector- http://www.rightlook.com/index.asp?P...ROD&ProdID=167
Alternative product -
Professional Plastic Restoration System - Use on all plastics: Acrylics / Plexiglas, Polycarbonates / Lexan, Gel Coats, Fiberglas - http://www.danase.com/prplresy.html
Note- place a microfiber cloth between the ‘folds’ when the top is down; this will avoid friction scratches on the viynl
