Easiest Wax To Apply?
Subscribe
May 15, 2007 | 08:33 PM
What would be the easiest and most durable wax to apply? No prepping, no clay bar, just a thorough wash followed by a paint protect-ant.
Reply 0
May 16, 2007 | 06:05 AM
A wax or sealant can only reflect what is underneath it, so a clean, level well-prepared surface is the most important consideration (85% of a surfaces reflectivity is its preparation) along with applied product clarity.
If you apply a product over a surface that is dirty or one that has surface imperfections a wax or sealant will not disguise it, only highlight them.
Reply 0
May 16, 2007 | 11:36 AM
The most durable wax is tough to say because waxes are generally not considered to durable. Natural waxes have a higher concentration of moisture and are therefore more affected by temperature changes. Sealants are made in labs to replicate what waxes do, but better. In general sealants give you a longer lasting shine and better protection than natural waxes. This is done by taking the molecular composition of wax and removing elements that don't add to greater shine, durability, ease of use, etc. For best results make sure you have taken all the necessary preparation steps to clean and smooth out the clear coat. The cleaner and smoother the clear coat is, the better the sealant will bond to it. The very high melting point of sealants makes them more durable and resistant to nature’s elements, abrasions and harmful contaminates. Contaminates have a more difficult time bonding to the clear coat, through the sealant, therefore its easier to remove contaminates during the washing process. Sealants typically give you full protection for 3 – 9 months depending on the sealant you select, number of coats and the prep work. Sealants give off a great reflective shine that lasts for months too.
There are a lot of sealants that are easy to use but I can say one stands out for ease of use and durability above many others that I have used. The Menzerna Full Molecular Jacket is very easy to use and lasts 4 - 6 months on average. I've even had some experienced detailers ask me if they were using it correctly because it's so easy to apply and remove. It can be applied by hand or with a buffer.
If you want the easiest wax to use I'd have to say the Pinnacle Souveran Paste Wax is very easy to use. It lasts anywhere from 1 - 8 weeks depending on conditions. It's super easy to apply and remove, but it must be done by hand. This wax leaves the surface looking super glossy and "wet".
These are my two favorites from the products I have used and I recommend with high confidence that you'll really like them. Let me know if you have any questions or if you'd like other recommendations.
Greg @ Detailed Image
Reply 0
May 16, 2007 | 01:35 PM
Thanks.
Reply 0
May 16, 2007 | 05:10 PM
Some protectants have a cleaner in them....like KLASSE All In One. Easy on and off and lasts a long time. Why are you against claying? The process is very easy, simple, and works well. It will make whatever you put on look better and last longer.
Reply 0
May 16, 2007 | 07:57 PM
greg is the man for good products and knowledge. For easy on and off p21s is killer
Reply 0
May 16, 2007 | 08:16 PM
The Klasse AIO is also quite easy to use and the P21S Carnauba Wax is also very nice. Both are great options but I just had to list my favorites. Thanks for sharing your info guys!
Reply 0
Subscribe
Currently Active Users (1)
