How do I keep the interior clean of a C230 sport?
nrsgaby
nrsgaby
That is the scariest thing I’ve heard about a dealer supplied product; I would not like to contemplate what it would do to the interior finishes of vehicle, leather, upholstery, carpet etc) my advice on how to use it- find a garbage can open the lid and place the ‘stuff’ in there
Between these four cleaners you should be able to remove 99% of stains occurring in a vehicle and around the home –
(a) 303™ Rug / Upholstery Cleaner & Spot Remover
(b) P21S Total Auto Wash (a citrus-based all purpose cleaner (APC)
(c) Woolite® Heavy Traffic Carpet Foam or Hoover Deep Cleansing Carpet/Upholstery Detergent
(d) Folex Instant Carpet Spot Remover
And as suggested Leatherique for leather upholstery
PS: Congrads on the new ride
For your interior; leather, glass, carpets, dashboard, console, trim and more I recommend our Interior Kit # 3. The 303 Fabric Cleaner is the premier interior cleaner because of its ability to easily separate contaminates and lift them for safe removal. Spray the 303 on fabrics with a firm bristle brush to deep clean fabric surfaces and remove deeply embedded stains. It also works on most of your interior surfaces (vinyl, plastic, rubber, fabrics) so one bottle can clean virtually your entire interior. This product can be used at full strength but we recommend diluting it to a 8:1 ratio of water to cleaner. This means you’ll get 256 ounces of cleaning solution from one bottle. Follow up this cleaning by protecting the surface with the versatile 303 Aerospace Protectant. The 303 Aerospace Protectant has SPF 40 for any vinyl, rubber, plastic, leather surface that blocks UV harmful rays and prevents slow fade from sun exposure. Apply this to the dashboard, armrests, tires, plastic trim, rubber seals, moldings, seats, etc. and you’ll see a brilliant shine without the greasy oily feeling that many other generic products leave behind. Don’t forget to protect the fabrics as well with the 303 Fabric Guard. Just spray the 303 Fabric Guard on all of your fabric surfaces for valuable protection from spills and regular traffic. For glass I clean regularly with the Invisible Glass, it’s a great streak free shine and safe on all tints. I also recommend using the Glass Science Rain Clear Kit, which comes with both the Rain Clear Gel and Glass Scrub. Use the Glass Scrub first to deep clean glass and get rid of any embedded deposits like lime scale, acid rain, water marks, etc. After deep cleaning the glass protect it with the Rain Clear Gel. It seals the pores in the glass and prevents moisture from clinging to the windshield. This forces water to form very tiny beads and makes driving in any rain very easy. To clean the leather and condition it use the Leatherique Prestine Clean with a terry cloth applicator. Rub it into the seats with the applicator and wait about 15 – 20 minutes then remove with a damp microfiber towel, followed by a dry towel. If you want a really deep conditioning that really helps revive the leather apply the Leatherique Rejuvenator first. Apply it liberally and let it bake into the seat by letting the seat sit in the sun all day. Then put the Leatherique Prestine Clean right on top of it and follow the removal procedure listed above. After your done your entire interior should be thoroughly cleaned and protected for a stunning appearance.
These are most of my favorite products that I use personally and professionally. All MBWorld members get 10% off at Detailed Image if this kit or other products interest you, when you use the code "10offMBW". Let me know if you have any questions about these products or any step in the interior detailing process.
Greg @ Detailed Image
