Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
removing airbag warning stickers from visors
Old May 31, 2007 | 10:47 AM
scottmlew's Avatar
Looking! (previous: CLS55)
(sorry if this isn't the best forum for this, but it looked like a good match)
I have an alcantara headliner and would like to remove the airbag warning stickers from the visors (also coated in alcantara). I gently started to peel away the corner to see what reside would be left, and it looked like it would be extensive, so I quickly reaffixed the sticker. Does anyone know how to get these off without leaving evidence on the alcantara?
Old May 31, 2007 | 11:35 AM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
I use goof off to remove those silly stickers. I have removed them on my Sl55 and my E55 that have the alcantara visors without any problem. You will have to soak the labels with goof off applied with a cloth and rub gently once it has had a chance to soak in. Don't be alarmed that there is some of the adhesive on the visor, just change the cloth, put more liquid on it and rub again. I always followed it up by applying it to the entire visor once everything was removed in order to avoid a stain.
Old May 31, 2007 | 03:02 PM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
You've got my attention- the little I know about Alcantara -
Do not use steam, solvent or spirit based cleaners (particularly perchloroethyene and trichlorethylene). But if it works for you...
