Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
How to: Conditioning leather seats with Leatherique
Old Aug 3, 2009 | 02:09 PM
  #176
Greg@DI's Avatar
Originally Posted by Jen_Kenne
Thanks. That is logical. Any experience with Connelly's Hide Food or Resurrection Oil? Or, for that matter, Neatsfoot Oil from the Tack Room?
I've heard good things about the Connelly's Hide Food on true natural leather. I've used the Neatsfoot Oil from Lexol and it worked okay, but not a top quality product. Not sure if this is the same product or not.
Greg @ Detailed Image
Old Aug 3, 2009 | 02:32 PM
  #177
Jen_Kenne's Avatar
my wife wild, but she loves every minute of it.
Thanks Greg!
Connelly supplied the leather for a few British cars and for Ferrari -- for a while. It was a surface dyed leather. Hide food is a creame, and contains lanolin and some other goodies. Their Resurrection Oil seemed similar to Neatsfoot Oil -- which has been a tack room staple for longer that we've been alive. Any of the vinyl/plastic coated leathers could not profit from something that must be absorbed. My 560SL's black leather was softened by using the Resurrection Oil. Washed with saddle soap first, then heated Resurrection Oil applied with a brush.
When did MBZ start coating their leather? I have a 2004, and suspect that it is one of the coated years.
Old Aug 15, 2009 | 05:16 AM
  #178
walee112's Avatar
2016 GLE400
off topic... so im cleaning my leather and what not tonight... and as i apply the stuff onto my seats (c55) with the perforations... how the hell do i get the conditioner stuff out of the tiny perforations? my microfiber just doesnt cut it!! ahhh its driving me crazy!
Old Aug 15, 2009 | 07:36 PM
  #179
lars's Avatar
05 CLK 500 cab
You could try a nail brush or a toothbrush, something with bristles soft enough to move the conditioner out of the pores and back on top.
Old Aug 24, 2009 | 10:03 AM
  #180
Jen_Kenne's Avatar
Originally Posted by Kar don
Here is what I reccommend to use leatherique. Buy Leatherique Rejuvenator Oil and Pristine clean, i suggest getting 32oz of each from www.leatherique.com This is by far the best leather product i have ever used, really cleans the leather very well, and makes the leather buttery soft. here is how i apply it.
1)Vaccuum loose dirt off leather
2)Put the Pristine clean in a clean spray bottle.
2)Massage 3-4 ounces of the rejuvenator oil onto the seats with your hands really working it in, i like to recline the front seats a little bit so the oil will soak into the back rests. Try and get every part of the seat, especially the seams. I like to do it when it is at least 65 degrees out. If it is colder out run the seat heaters but just make sure the sun isnt directly on the leather.
3)Let the rejuvenator oil sit on the seats for a full 24 hours for best results, minimum 8 hours. You cannot drive it during this time.
4)After the RO(rejuvenator oil) has sat on the leather for that amount of time, you should see a lot of dirt that has lifted to the surface and it will feel tacky. Spray the Pristine clean onto the leather (about 1-2 oz) and wipe off with a cotton terry cloth towel. Try and get every part of the seat. Do this to all the seats u did with the RO.
5) Now I like to take a damp (with water) new towel and wipe all the seats down again.
6) Buff the seats with a microfiber towel, and you are done.
You should have no shine on your seats now and if you want them even softer, start the process all over again. Good luck! Post results if u try it. Here is an example of this process done on a caddilac. The top pic is before (note the dirt and shine in the leather) the bottom is after and butter soft.
This pic is courtesy of gmblack3 on autopia
Bump.
I've had similarly good results using Lexol and Connolly's products, as well as Neatsfoot oil from a Tack Shop. One key is to determine if your leather is coated or not. If it's coated, the oils 'probably' cannot get to the leather.
Old Sep 18, 2009 | 02:16 PM
  #181
walter34payton2's Avatar
2006 e350
What about the MB leather care foam. I use it. It doesn't seem to do much for my 2006 E350 and the leather stays sort of stiff. I used to use Armor all leather care, which made leather softer, but I didn't trust it so I decided to just use what dealer said to use. They said to use the MB foam only. What is in that? Anyone think it is protecting my leather. I am afraid that it will crack from the sun if I don't use something else or will the foam suffice?
Old Dec 15, 2009 | 12:53 AM
  #182
Kvn22's Avatar
24' G63,21' AMG GTR, 24' McLaren Artura, 17'' GLS63S, 24' GLE63S, 08' CL550
Any images? Thanks
Old Dec 21, 2009 | 09:20 PM
  #183
jaime's Avatar
SLK 350 DESIGNO 2007 SILVER/BLACK-MISTIC RED
MB foam its a cleaner that conditions the covered leather as well, and it has an "antistatic" property that avoids the dirt get into the leather. Since the leather has a vinyl/plastic top, it has menor treatment requirements: practically, this kind of (covered) leather is endless. MB says the leather will last the same period tha the car itself.
There is a italian product specially made for covered leathers, which is used extensively in Europe. It consist in 2 products: the cleaner and a protective cream. Chek the site http://www.uniters.com/
I have been using leatheerique, which is great product, but only on old english leathers/not covered leathers. Leather Masters products, are, in my opinion, the best product you can use on covered leathers: I have been using it for the last years and I like it more than leatherique.
Best regards fellows.
Old Feb 5, 2010 | 10:32 PM
  #184
pushtiulk's Avatar
2007 Fiat Panda 1.3 JTD
I've attached a pdf with useful info about leather (from the beginning until covering the car seats. The book was written by George Pavlisko (creator of Leatherique).
File Type: pdf
Old May 9, 2010 | 10:11 AM
  #185
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
I somewhat skimmed through this, 2005 sl600 a covered leather?
Old Jul 21, 2011 | 05:29 AM
  #186
italyatalanta's Avatar
2004 E320
now i wonder if the E320 2004 has leather or clear coated leather
Old Dec 29, 2011 | 08:05 AM
  #187
pushtiulk's Avatar
Even clear coated leather can be cleaned with leatherique!
Old Dec 30, 2011 | 03:54 PM
  #188
lars's Avatar
05 CLK 500 cab
I've used Hide Food to soften and clean a couple of MB gearshift boots with good results.
Old Aug 31, 2012 | 07:01 PM
  #189
serialize's Avatar
79 300SEL
Great read/thread.
I'm interested in getting the Leatherique Prestine Clean and Rejuvenator Oil .
My question is, if I'm not planning on "rejuvinating" my leather, just regular cleaning and maintennace, what are the exact steps?
- Leatherique rejuvinator oil first ?
- Let rejuvinator sit on seats for 24 hours ?
- Then clean off seats with Prestine Clean to finish the process ?
Also there was mention that the pristine clean can be used on the rest of the interior (dash, grills, etc etc all the non-leather stuff) ?
Thanks for all the great info/feedback.
Old Nov 14, 2013 | 08:53 PM
  #190
6G Schnell's Avatar
2021 E63S and 2025 GT63
Exclamation Silver Stitching
Any caveats with applying Leatherique to seats with silver stitching?
Could it stain / turn into yellow stitching?
Attached Thumbnails How to: Conditioning leather seats with Leatherique-image.jpg
Old Sep 25, 2014 | 12:26 AM
  #191
GCURTIS1's Avatar
C300
I have a 2010 c300 with the perforated seats ventilation so what are you guys saying I shouldn't have to clean them because the leather it is covered or I should clean them.
Old Sep 25, 2014 | 12:41 AM
  #192
6G Schnell's Avatar
Search for more on this topic to hear others opinion; it should work fine with perforated seats
My 2c it works great, applied to my new car in January and today seats have look and feel as if I just picked up the car from dealer
Downside is car may not be usable for 24 hours, or so, while applying cleaner and conditioner.
Old Sep 27, 2015 | 08:22 AM
  #193
red60R's Avatar
2017 C63S
I wish we could get all the current leather specialists to update this section. I see the thread started back in 2002. I am definitely no leather expert but I can tell the MB has used different materials on the various cars I have owned from the 2006-2009 range. My newer C63 seems much different than both my ML, C65, and E55. The other three all have the ventilated/active seats with the little holes all over them. I have been hesitant to put anything thick that could clog those. The C seems to be a different leather altogether and gets an odd shine on it (almost like it shouldn't have) using Meguiar's.
Do most of you guys use Lexol, Zymol, Griott's, something else?
Old Nov 25, 2015 | 01:39 AM
  #194
xxfightclubxx's Avatar
s550
i have a s550 and my leather definately needs some care from steering wheel to seats. not really sure where to start. ive used the armor all leather cleaner and conditioner. but im sure theres alot more to it then that. i want my leather to be softer again and not sticky feeling.
Old Nov 26, 2015 | 02:11 AM
  #195
6G Schnell's Avatar
Leatherique is the best in my opinion... Especially when you want to restore leather
Old Jul 31, 2019 | 12:59 AM
  #196
Naeblis's Avatar
2009 E63
Maybe this will get fully updated, but doing details myself at one point and working with some professionals the consistent feedback I got was clean, not condition. Adding the oils/lipids in most products titled as conditioners simply turns seats into a dirt attractant. Like attracts like, and having a layer of what is essentially grease sitting on top of your seats is just going to pull oil, fats, and dirt from your body and anything that comes in contact with them. If you want your leather to stay in good shape keep it clean so that it doesn't build up grime and begin to dry out and crack from built up abrasions. There are some protectant options as well, but for the love of your leather, stay away from the gooey stuff.
Old Jul 31, 2019 | 01:22 AM
  #197
6G Schnell's Avatar
Have you, or professionals you talked about, seen what is Leatherique about?
http://www.leatherique.com/products.html
Old Jul 31, 2019 | 01:41 AM
  #198
Naeblis's Avatar
2009 E63
It's late so I probably should have been more clear rather than overly general, I was just bored. I mentioned most as I meant that. Most of what gets labeled as a conditioner is a hot mess that will leave leather worse in the long run. Most people here aren't going to need to drop C notes on products to restore completely dried out surfaces, and my comment is more directed at those who have a vehicle they're simply trying to maintain. As always, an ounce of prevention is worth a pound of cure. Keep leather clean and maintain its condition. I'm also not a fan of products that break down and soften leather, but to each their own.
Old Aug 1, 2019 | 04:07 PM
  #199
Bananamani's Avatar
2017 C43
Im wondering this as well. Anyone have any experience with this?
Old Aug 1, 2019 | 05:38 PM
  #200
6G Schnell's Avatar
Yes, applied to E63 black seats w/silver stitching and no change in color.
recently used on C43 with silver/black combo leather seats ...
hope this helps.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
